Rims 17x9 or bigger
Old Apr 5, 2010 | 01:53 PM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Rims 17x9 or bigger
I want to see pics of rims that are 17x9 or larger that don't need spacers and actually fit our cars. I bought some black Vette rims for the gta but the more I think about it the less I want to use spacers. I just wanna see what options I have in case I decide to sell the rims.
Old Apr 14, 2010 | 02:05 PM
Transmetal's Avatar
Re: Rims 17x9 or bigger
No one has pics?
Old Apr 14, 2010 | 05:58 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here are the SLP 17x9.5 Firehawk wheels by Ronal.
Old Apr 17, 2010 | 11:28 PM
Transmetal's Avatar
Anybody else got any?
Old Apr 18, 2010 | 12:01 AM
Zepher's Avatar
there aren't that many.
ROH Snypers
SLP Firehawks (ones I posted)
SLP ZR1 style, but they are 17x8
Fikse FM5 and FM10 ($600-900/wheel)
You can swap out the rear and just run spacers on the front. I've been running spacers on my car for 6 years or so with no issues. I've had an LS1 rear end on the car for the same amount of time.
here is a cool thread with lots of wheels. you'll need to find out if they are bolt on or need spacers though,
https://www.thirdgen.org/forums/whee...g-3rd-gen.html
Old Apr 18, 2010 | 01:47 AM
Transmetal's Avatar
My main issue I have with the adapters/spacers is the weight of them plus the added weight of the bigger rims and my car is gonna move slower than the line at the dmv. It's just a 350 with a few bolt-ons. I wouldn't mind the stock rims if they were black and were wider than 8 inches. What about the Yearone 17x9 snowflake wheels, I wonder what those look like with black inserts instead of the gold?
Old Apr 18, 2010 | 02:42 AM
Zepher's Avatar
I've got a 305TPI car and mine can move.
http://www.youtube.com/watch?v=FqPDihdQEJc
http://www.youtube.com/watch?v=0GAKT...eature=related
yours should be a bit faster than mine.
Old Apr 18, 2010 | 02:48 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
dude.. you're talking about losing 1/10 of a second... performance loss you won't even notice...
Old Apr 18, 2010 | 12:07 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
There was a debate somewhere on these forums as to whether using spacers was 'safe' or not for certain applications... I think the general consensus was that as long as you check the 5 bolts that bolt the spacer on the car (which is hidden under the wheels and requires removal of the wheel) and everything is tight under there, then nothing is dangerous about it. Basically 5 more bolts to check every now and then. Skulte used to make them but i think they stopped for whatever reason
Old Apr 18, 2010 | 12:28 PM
Stephen's Avatar
Car: 87 GTA
ROH Snypers, direct fit to 3rd gens (they also made 4th gen fit Snypers) 17" x 9" w/275s front, 17" x 11" rear w/315s rear.
Check my sig for links to more pics.
Old Apr 18, 2010 | 02:17 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
ROH Drift Rs also fit.
Running a 305 35 on tha back. I cannot remeber if it is a 10 or 11 inch rim. No spacer needed. This car used to see regular track duty and will again now that it is running.
Old Apr 22, 2010 | 05:39 PM
krazefbird's Avatar
Car: 84 Firebird
Engine: currently 1968 307
Axle/Gears: 3.23 lim slip
Anybody know if the ed miller brake conversion kit changes the bolt pattern on the wheels? Looking into aftermarket rims without having to pay #$%%^ for a set
Old Apr 22, 2010 | 05:47 PM
Stephen's Avatar
Car: 87 GTA
It doesn't.
Why would you even think it might?
Old Apr 23, 2010 | 07:27 AM
Transmetal's Avatar
I know when I put rims on the Grand Prix I could feel the difference with the extra added weight of the rims. That's why I brought it up.
I see the torque thrust 2's come in 17x9.5 but everybody has those plus they don't really "fit" the gta.
Old Apr 23, 2010 | 01:35 PM
krazefbird's Avatar
Car: 84 Firebird
HA! just hoping it might. Thought I had a set all lined up and then started looking a little closer and I think the bolt pattern is going to be just about that much off which would mean a waste of time and money. Just to let you know what I was looking at, they were the Mesh X wheels from MB wheels. Saw the same pattern on another bird but they were custom made by Boze wheels out in CA and I called them the other day and they said $2100.00 for a set. MB wheels would run me 500.00
Old Apr 23, 2010 | 03:08 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
That was the going price for the DRIFT Rs once delivered and fitted with Sumitomos
Old Apr 25, 2010 | 06:58 PM
tslsa28's Avatar
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
You can get new wheels from www.vintagewheelworks.com. They are expensive but a 17"x9.5" with 5.5" backspace fits with no spacers. They are much lighter than Ronals or ROHs. I have some good pictures of my car with the V48s but the file is too large to post. I can e mail to you if you want to give me your e mail address.
Old Apr 25, 2010 | 07:03 PM
Stephen's Avatar
Car: 87 GTA
You can just bring it up in something as basic as MS Paint, resize it then upload it. Or then upload it to a Photobucket account (if you have one) & post it from there.
Or you can send it to me, SDC78605@Austin.rr.com & I'll do it all for you & give you the link to use it anywhere.
Old Apr 25, 2010 | 07:31 PM
tslsa28's Avatar
Thanks. I just emailed it to you. I don't have MS paint on my office computer.
Old Apr 25, 2010 | 09:53 PM
tslsa28's Avatar
Here's pictures of the Vintage Wheels. I don't use the center caps on the track. http://s119.photobucket.com/albums/o...newwheelsb.jpg
Old Apr 25, 2010 | 10:02 PM
tslsa28's Avatar
Here's more pictures of the Vintage Wheels. See my notes in previous posts. Thanks to Stephen for making the picture files.
http://s119.photobucket.com/albums/o...ewwheels4b.jpg
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
sjorgens
Oct 1, 2015 07:54 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
