Beast summer grip period.. for street use? 16
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Im looking for a brand of 245 50 16 that will own the road..not looking 4 road race tires.. just the best o a street tires...
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Beast summer grip period.. for street use? 16
Go with a set of nitto drag radials or go 255 with a set of m/t street radials. M/A makes a nice street radial also. Mickey Thompson also has a street series sportsman which have a sporty and aggressive tread design and then the sportsman pro which have a more reserved tread pattern for the strip but the pros run a little wider than what you want. Now if you want a set of tires that are a little less sticky and less race oriented you can do a set of 245 coopers they offer a good price and they stick well. The drag and street radials are going to be the beasts though.
Car: 1985 IROC-Z
Engine: 355
Get the nitto 555 street tires for the front they match up pretty well as far as looks with just more of a street-able design. extreme street i think they are called? Or get them all around and an extra set of rear wheels for some drag slicks/radials when your gonna run it. That's basically what i do. I'm running 245/50/16 Michelin in the rear and 225/50?/16 i believe in the front. Also have a set of summit stars that im still looking for a set of tires for. 15x10 in the back and 15x4 in the front was thinking on the M/T et streets 27/10.5/16 havent got the money for rubber all around now so ive just been doing allot of research.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I wish i could get the nt555 up front but they don't sell them in my stock size..
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Eagle F1 GSD3's were the best but Goodyear has none left and are not producing them at the moment (hopefully not indefinitely). Second in line for that size would be something like Fuzion ZRi's or Firehawk wideoval indy 500's.
Car: 1985 IROC-Z
Engine: 355
Ive heard good things about the fuzion ZRi's. Ive also heard they have been hard to find lately idk if thats just a rumor. IMO i dont really like the way the Fuzions look the sidewall writing looks tacky and the tread as well. But i have heard they grip. For a strictly street tire Ive heard that the gsd3s are the best as far as grip is concerned i wanted to pick up a set. I work as a mechanic for sears and the last time I was in the tire basement I saw a set of the gsd3s I looked them up in the comp and sears wants somewhere around 280-300 a piece.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I wish thay still made GSC i love the tread pattern. Are you sure the ZRi are a good tire? they sure are cheap !!
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
