z06 Wheels
Car: 1984 Berlinetta
Axle/Gears: 3.08
z06 Wheels
Hey guys, what tires would i have to run to put stock z06 wheels on my 84 camaro? Also would i have any rubbing issues?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: z06 Wheels
you could run the stock z06 sizes. you will need spacers to use the wheels
Axle/Gears: 3.08
Car: 86 Trans Am
Car: 3 1969's and original owner 1987
Re: z06 Wheels
Yeah but you have to measure the back spacing of the wheels first. As long as your under 6" of back space with the wheel and spacer together for the rear you will be fine. Here is a chart that I used to determine what I needed.
http://www.skulte.com/adapterfaq.html
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
Re: z06 Wheels
Im running 18x9.5 with 245-45-18 with a little bit of rubbing on the front but only when i turn the wheels like half way.
Also using 2" spacers all the way around
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: z06 Wheels
do your tires looked like they are stretched onto the rim?
Supposed to have 275/35/18 tires on that width.
Re: z06 Wheels
You need a total backspace of 4.6" with the wheel and spacer together for it no to rub. You say you have 2" spacers now and I bet you have a 6.8" to 7.1" backspace on your front wheel. I would jump up to a 2.25" or 2.5" spacer especially if your going to the 275/40s soon.
Re: z06 Wheels
ok cool thanks for the help I would have never thought about getting a little bit bigger of a spacers.
Car: 89' IROC
Axle/Gears: 373
Re: z06 Wheels
I have P315/35R17 drag radials and it doesn't rub because I have the right size spacers so the wheel offset is perfect. As in you case 335 is pushing it but I dont see why it wont work with the correct back space with your wheel and spacer combo. What is the back spacing of your rear wheel?
punkmaster98
Sep 8, 2015 09:45 PM
