Why no 18" AR IROCs in 9" or 10" widths?
Old Aug 30, 2010 | 09:06 AM
puma1552's Avatar
We know they can fit (maybe the 10s wouldn't fit on the front but they would on the rear), so why are we limited to 8" widths on the 18s?
Also why has nobody made a polished aluminum version yet?
Polished 18x9s all around would be better than chrome 18x8s IMO.
Old Aug 30, 2010 | 01:47 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Why no 18" AR IROCs in 9" or 10" widths?
I've long wished for 18x9, with a +13 mm offset, that are neither polished nor chromed.
Old Aug 30, 2010 | 04:58 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
get the rears widened, i'm not exactly sure how an 18x10 with 295's would look but i don't see an aggressive style in the irocs to look right with such a wide tire, maybe 18x9 with 275's all around would look great.
Old Sep 3, 2010 | 10:17 PM
puma1552's Avatar
Yeah it just seems weird that AR isn't making them in 18x9 sizes...no idea why, and kind of a disappointment.
Old Oct 18, 2010 | 10:04 AM
puma1552's Avatar
If you got them widened to 9" all around (effectively adding an inch of backspacing), would they fit with 275s all around?
Old Oct 18, 2010 | 01:53 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Yes they would.
These guys do wheel widening
http://www.weldcraftwheels.com/index.html
Old Oct 18, 2010 | 06:49 PM
puma1552's Avatar
Originally Posted by The Project
Yes they would.
Would you still be able to turn the wheel to full lock with that without any rubbing, and with the car lowered on sportlines?
Old Oct 19, 2010 | 08:20 AM
Car: 89 IROC
Personally I'm not sure. Some people have experienced minor rubbing but can still fully turn while others have had no issues.
I believe up to a 5.5" backspace there are no issues.
Old Oct 19, 2010 | 09:07 AM
puma1552's Avatar
That's what I've heard. With widening, that would put it right smack at 5.5", which may be a little close for comfort. I refuse to make any permanent modifications to the car just to make a tire or wheel fit.
In any regards, I contacted that company you gave me, their work looks great, I just got an email back about widening those IROCs by 1 inch...$220 per wheel
The wheels are only $200 each.
Guess I'll, uh, stick with 18x8s and a 245 if I go with the IROCs.
Old Oct 19, 2010 | 12:18 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
5.5" in the back would fit fine then you can at least throw on some thicker rubber.
Orr89RocZ
Feb 13, 2016 10:04 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
