swapping 4th gen wheels on 3rd gen
Old Oct 17, 2010 | 07:42 PM
camarodubs's Avatar
Car: 1987 camaro
Engine: gm goodwrench crate 350 mild
Axle/Gears: 28 spline 7.625 10 bolt w/273
Hi, I recently purchased some 96 camaro wheels that are 16x8, and I went to a wheel shop to get some spacers and they said that I needed 1.25 spacers and I installed the wheels, and they fit good on the rear but they rub on my tie rod ends in the front . It seems like that I only need about a quarter inch to get the clearance that I need. I also have seen where everyone says 2" spacers are needed. Can someone please give me some input I dont wanna buy 4 new spacers. thanks for any help
Old Oct 17, 2010 | 07:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: swapping 4th gen wheels on 3rd gen
it depends on the specs of your wheels, sometimes people use 1.5" spacers, other 2.25. If the wheels are 16x8, you want to end up with around zero offset, or 4.5" of backspace after installing the spacer. So measure from the mounting surface to the inside edge of the wheel, subtract that number from 4.5, and thats the size spacer you want. You may have to round that number, it will probably be fractional.
Old Oct 22, 2010 | 05:22 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Hi,I have 16x8s on my 85z,and I have 2'' spacers all round.On rare occasions they will rub slightly,but only on a very tight turn,ie on full lock.The wheels are off a 93 firebird.
Old Jan 12, 2011 | 01:00 PM
Smoothy's Avatar
Car: 89 Camaro RS
I want to install 96 WS6 wheels(17"). What spacer do i need on front? I have a 4th gen rear axle. Do i can install the Rear Wheels without Spacer? Do you have photos with ws6 wheels on camaro?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
