What the correct PSI
Car: 92 Camaro RS
Engine: 3.1
Transmission: Manual
i have a 92 camaro 3.1... i have 345/35/20 on the car and putting in new tires.... just wondering whats the correct psi
and if it help i am getting n3000 from nexus
and if it help i am getting n3000 from nexus Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What the correct PSI
the max and usually the minimum recommend pressure is on the tire....
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
The magic number for the Nexen N3000's seems to be 41psi for the best tire footprint and performance. I'd personally run them with no more than 35psi for a little extra cushion, especially being a 35 series tire.
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
I typically fill on all tires 33 front and 32 Rear for better grip.. whether it's fact or fiction, dunno... but haven't had any problems thus far...
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Never heard that one ^ before. No logic behind that which I can think of that relates to proper inflation relative to the vehicle.
There is a chart on the door by the latch(or in the vicinity depending upon which specific vehicle) that lists pressures for the stock size, and that shouldn't vary inless you have an odd situation such as the OP may have.
The max psi listed on the tire is for the maximum load rating on the tire. If you are loading the tire to it's max weight with one of these cars you need a different tire or are asking for trouble.
30-35psi is normal for a passenger car. If you have the wrong size tire for the wheel, or have clearance issues, adjust accordingly.
