Will these fit without rubbing suspension?
Old Nov 1, 2010 | 09:59 PM
Daytona_83's Avatar
Car: 1983 Pontiac Trans Am "Daytona"
Engine: LG4 305 V8
Transmission: T5 5-speed
I'm wanting a set of 17x8 (fronts) and 17x9.5 (rears) wheels. The fronts have a "0" offset and the rears have a "+6" offset. I'm using http://www.rimsntires.com/specs.jsp to find out how they'd fit. Says that the fronts will fit no problem. The rears, however, it says they'll be 1.4" closer to the suspension and such than stock. Will that be a problem? Will I have to run the 17x8's in the rear too?
Old Nov 1, 2010 | 10:15 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Re: Will these fit without rubbing suspension?
Yes, the rears will also fit fine. They have about the same offset as the SLP/Ronal Firehawk rims if you want to see what they might look like.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
