Will a 17x10.5" wheel fit?
Old Jan 6, 2011 | 09:03 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Hi everyone...been looking hard at the American Racing Torque Thrust "M" wheels in either the black or anthacite. I'd like to put the widest meats I can on the rear, and after researching it seems a 17x10" wheel will fit without mods and a 5.5" backspace.
But unfortunately, the closest I can get with these particular wheels is a 17"x10.5" wide wheel with a 44mm "offset"....or else I need to drop down to 9" width...
I'd like to run a 285/17" tires on th rear, which I know the 10.5" wide wheels will accomidate - but I'm concerned about that extra 1/2" of width. Will I need to cut out bumpstops and hammer, or do you think I could get a spacer that'll tuck everthing in without any mods to the wheel well??
-Or- this style rim goes straight down from 10.5" wide to 9" wide...am I better off just going down to a 9" width and running 275 tires?? At wheelsforless, I can get them with Nexen N3000 tires monted and balanced pretty reasonably....
Thanks in advance for any opinions on this....
Old Jan 8, 2011 | 12:21 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Will a 17x10.5" wheel fit?
2" spacers ought to do it but they are going to stick out a bit.
Old Jan 8, 2011 | 12:41 PM
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
Where is a place to buy good quality spacers?
Sorry for highjacking your thread..........
Old Jan 8, 2011 | 04:47 PM
watajob's Avatar
Car: 92 T/A 'vert
Originally Posted by 1fas92
Hello,
http://www.motorsport-tech.com/
Not cheap but not Chinese sh_it either. Don't skimp on something that's going to make your life overly exciting if it fails.
Old Jan 9, 2011 | 09:05 PM
Confuzed1's Avatar
Car: 83Z28 HO
That's what I was afraid I'd hear....so if I got, say...a 1 3/4" spacer I would probably hit the bump stop or somethng else??
I def. don't want the tires sticking out...tends to cut the sidewalls. lol
All this is sooo confusing....I read posts where the 285/40/17's fit perfect, and some say it will stick out. I realize rim width and backspace are critical to tuck this size tire into the rear wheel well, so - if I reverse the question...what size 17" rim and backspace would I need to fit these tires in the rear with no hammering and tucking under the outer fender??
As I said in my initial post, I could always play it safe and go with the skinnier 9" wide wheels, but from what I understand that'll restrict me to a 275/40/17" tire max....
It's kinda sad...I really like the Torque Thrust M wheels, but I may need to choose something else to get the rubber I need on back. I REALLY need traction.
Old Jan 13, 2011 | 05:19 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
I had the 285/40/17 on my 17X9.5 rims w/50mm offset and 2" spacers.They fit fine and looked good
Old Jan 13, 2011 | 06:30 PM
Stephen's Avatar
Car: 87 GTA
Just say NO to spacers. And buy wheels that fit, or mod the inner wheel wells to accommodate your wheels of choice.
If you just MUST get a wheel that doesn't fit & needs a spacer to fit, just get you a LS1 rear end. You'll no longer need the spacers AND you'll get bigger disc brakes AND a better posi unit. LS1 rear ends are a win-win mod, as long as the wheels don't end up out past the fenders.
Old Jan 13, 2011 | 08:24 PM
Confuzed1's Avatar
Car: 83Z28 HO
Are the LS1 rears stronger than the Moser 9" I currently have? But - it would be a way to get rid of the drums I currently have on the rear...
-But I here ya Stephen, I'd much rather use 20 lug nuts than 40...as much as I like those wheels, it seems like I'll need to keep looking around. I'm kinda "old school" (and gettin kinda old lol) and like the 5 spoke wheels - but it's hard to find any of that style that have the right backspace or offset to fit Thirdgen's. And just IMO, Vette (and TT2's) wheels are overplayed...not sayin there not nice cause they are...but A LOT of people have them. And they use spacers with most all of those too...
I'm really only looking at 17" wheels because there's not much selection in the 15" size tires like thier used to be.
Old Jan 13, 2011 | 08:29 PM
Stephen's Avatar
Car: 87 GTA
[QUOTE=Confuzed1;4787406]Are the LS1 rears stronger than the Moser 9" I currently have? [QUOTE]
Oh definetely. 10 times stronger. 10bolt > 9".....NOT! :roflmao: I missed that you already had a *ord part. (or was i choosing to ignore that? :lol )
Old Jan 13, 2011 | 09:03 PM
Doug Phillips's Avatar
Car: 85 IROC race car
Engine: 425/435 rwhp/tq
Transmission: WCT5 .80 5th gear
Axle/Gears: 3:42
If you want grip, buy a better tire.
285/40/17 is too tall. Stick with the 275/40/17
you can roll your fenders for more space.
stay away from big spacers.
buy my 17x9.5 Firehawks.
Old Jan 14, 2011 | 03:02 AM
dannyboyemt's Avatar
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Someone on the forum got 18x11 iroc's to fit in the rear with some slight modifications. Mr. IROC-Z. I would imagine 17x10.5 wont be too bad.
Old Jan 20, 2011 | 05:40 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I run 285/40/17's front and rear. and yes I do realize that they're nearly half and inch taller than stock.
Old Mar 23, 2011 | 12:35 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
bump for some info. I need to know what spacer size on the torque thrust m 17x10.5 with the 44mm offset to just barely fit inside the fender well... Not flush with it.
Old Jul 18, 2015 | 11:55 PM
asaman97's Avatar
Can someone please post a picture of their car with 17x10 wheels and tell me how it drives
Old Jul 20, 2015 | 08:05 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
you can put the 285/40/17 on the 9.5in rim wide without an issue. i run 285/40/18 on a 9in wide rim
Old Jul 20, 2015 | 04:48 PM
asaman97's Avatar
How's the turning? I'm thinking about getting some rims but they're 17x10 on all 4.
Old Aug 19, 2015 | 02:38 PM
roper88cars's Avatar
OK, So here is the skinny! our standard rear wheel is a 16x18 with a 16mm offset. if you go to a 10" wheel with the same 16mm offset you are going 1" to fender and 1" to suspension, you will hence clear all parts with no rubbing and not look old English meaning the tire will line up with fender but not stick out.
the only thing you will have to do is have your fender under lip rolled in.
Old Aug 19, 2015 | 08:11 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I'm going to be selling my 17x10.5 anthracite FR500 rims on my rear, they are a for bolt pattern but all u need is 1.5" adapters and your fine with no real mods. I cut my rear bump stops for added security but prob not needed. My fronts will be for sale as well at 17x9 with a 1.25" adapter. They have only 500 miles on them with new sumimoto summer tires. The rears are 315/35-17 and fronts are 275/35-17 and I have no rubbing. I'm stepping up to 20s and my new wheels/tires will be here tmrw.
Old Aug 19, 2015 | 08:18 PM
Car: 87 TA clone
These are the rims and tires. They are anthracite which is a dark gay. Rear is deep-dish style with polished and cleared rim. The front in this pic is with a 1.5" adapter and it now has 1.25" USA custom made adapters and they are not cheap, so the wheels are tucked in 1/4" more now.
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
