Will these fit?
Old Jan 7, 2011 | 10:41 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Will these fit?
I was wondering if these C6 ZR1 wheels would fit on my GTA? Im assuming that I will need some spacers?
http://cgi.ebay.com/ebaymotors/18-19...mZ380299032411
Old Jan 7, 2011 | 10:47 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Will these fit?
I really like these bad boys too. These are 19x11s in the back though, i dont think I would be able to get these on
http://cgi.ebay.com/ebaymotors/Ace-ZR1-Style-C5-Z06-C6-Black-Machine-Face-Wheels-/180329458402?pt=Motors_Car_Truck_Parts_Accessories&hash=item29fc792ae2
Old Jan 7, 2011 | 11:29 PM
Stephen's Avatar
Car: 87 GTA
Re: Will these fit?
I don't see the offset specs on the 2nd set. And yes, the first set will fit with spacers. The 2nd set probably will too, with the right spacers.
Get a LS1 rear end & you won't need spacers (or much thinner ones) in the rear AND you'll get the bigger/better brakes too.
Old Jan 7, 2011 | 11:58 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Will these fit?
The first set is 79mm off set which translates into over 8.5" BS which will require a spacer even with a 4thgen rear unless you want to perform surgery. The second set says C6 backspacing so they're probably even a little worse as they are an inch wider.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
