spacers right size?
Old Mar 9, 2011 | 08:00 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
spacers right size?
Just ordered spacers from hawksthirdgen. great quality just a quick question. I talked to them and they said they were 2", well i received a set... x2 1.5" x2 2" does the smaller one go in the front or rear?
I bought this in the intent of putting my oe 17"x9.5" c6 replicas
I talked to them already and they said they'll fit before i bought the spacers... so I just want to confirm if anyone else knows?
Old Mar 9, 2011 | 08:02 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: spacers right size?
http://www.skulte.com/adapterfaq.html
Old Mar 9, 2011 | 08:17 PM
tunnelram's Avatar
Car: 1986 camaro iroc-z
Engine: 463 big block chevy
Transmission: th350
Axle/Gears: 3:23 posi disc
hi, the thicker spacers go to the rear but, the thicknesses dont seem right. the average adapter/spacer with studs in them is usually 1" thick 1.5 and 2" seems like alot. just be sure the wheels dont hit the rear fender when hitting a bump.
Old Mar 9, 2011 | 08:37 PM
Car: GTA
Look at the link I posted above.....2" is the general use adapter for 4th gen/C4/C5/C6 wheels on a 3rd gen, front & rear.
Old Mar 10, 2011 | 06:43 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I thought so, i'll talk to them about this. I don't understand why they gave me a 1.5" set...
thanks!
Old Mar 10, 2011 | 07:40 AM
Car: GTA
Using different sized spacers will set the wheels sitting like the stock 3rd gen wheels. Narrower rear track width technically helps in tracking, although I've never the difference when I ran wheels that didn't give the car a narrower track width out back.
To retain the stock tracking, you'd want narrower in the back, which is what you'd get with what he sent you. They'll fit, just up to you if you wanna go that route.
Old Mar 10, 2011 | 05:02 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
sorry for stupid response, but to confirm what I've read, the rear will sit in more than the front?
If so i hope the tire size gives off the illusion of being bigger or sticking out more in the rear... I'm doing 245/40 front 275/40 rear
Old Mar 10, 2011 | 05:13 PM
Car: GTA
Not stupid at all.
The wheel will only sit in 16mm = 5/8" further.
It isn't so much of the wheel sitting inwards further, as it is the shallower outer wheel that gives the impression of a narrower front wheel, even though it isn't.
Where did you find those sizes in a 16" tire?
Old Mar 10, 2011 | 05:16 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Not stupid at all.
Did i mention 16"? sorry if I did, the oereplicas are 17"x9.5", got them from hawksthirdgen
Old Mar 10, 2011 | 05:32 PM
Car: GTA
You didn't. I was having a brain fart & thinking of the OEM wheel offsets.
Just make sure that the backspacing doesn't exceed 5" & all 4 wheels will fit all 4 corners.
Old Mar 10, 2011 | 05:35 PM
Car: GTA
Here is where I saw some good info, on front wheel size fitment.
https://www.thirdgen.org/forums/whee...ont-wheel.html
Old Mar 10, 2011 | 05:42 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Backspacing is measured from the sitting point of the wheel to the back side of the wheel? if so i measured i think 7.5"
Old Mar 10, 2011 | 06:29 PM
Car: GTA
Wow...Vette wheel specs. You measured right. You'll need 2.5" spacers up front.
Image isn't real clear to see on the measuring lines. Gotta look close, but you are correct. Wheel mount surface to rim edge.
Old Mar 10, 2011 | 09:03 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
2.5"?!?! holy crap... i hope your not serious. why would hawks screw with me when I told them specifically that i bought the wheel from them and they told me to buy these spacers from them, i gave measurements and everything.. this feels like a pain to deal with now..
Old Mar 10, 2011 | 10:10 PM
Car: GTA
On this page...http://www.skulte.com/adapterfaq.html I read...
Corvette ZR1 style (High Offset) 17x9.5 56mm 7.4" 2.25"
I do see another 9.5" wheel with lower offset that uses a 2" spacer. Maybe they misunderstood which wheel you had?
Corvette ZR1 style (Low Offset) 17x9.5 38mm 6.7" 2"
I guess there are 2 different 9.5" Corvette wheels, with different offsets.
I read in this thread https://www.thirdgen.org/forums/whee...ont-wheel.html and somewhere I saw a pic that apparently shows that a 17"/5" bs is wheel VERY close to a tie rod end.
It sounds to me like your 7.5" bs wheel needs a 2.5" spacer to get to the 5" bs mark to clear the tie rod. If I'm wrong in my reading of all this & understanding it, somebody please clarify it for me.
Old Mar 10, 2011 | 10:31 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
http://www.hawksthirdgenparts.com/20...518x105-1.aspx
these are the wheels just so you know..
but yeah idk :\
Nervous2
Oct 8, 2015 10:53 PM
the_hamturdler
Exterior Parts for Sale
Sep 21, 2015 08:55 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
m00n420
Sep 11, 2015 02:39 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
