Advice for over tightened lug nut
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Okay, so I'm going to replace the brake pads this fine spring day...am halfway through and taking off the wheel on the driver side...run into a stubborn lug nut (stock). End up BENDING a 4-way on it...then the nut rounds off. So step two...pound a metric 18 socket onto it and try with a 1/2 inch drive ratchet. Didn't budge, and ended rounding some more. This lug nut is on a Pontiac stock wheel, recessed in about 2". Does anyone have any ideas other than what I've done that will make it easier?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Advice for over tightened lug nut
pound another socket on it, or buy the specail removal tools form the local auto parts store, and use a impact gun on it. (if you dont have one, your SOL). the impact gun will do a better job breaking loose a tight lug than a ratchet or breakler bar ever will
good chance the lug is actually crossthreaded, not overtightened, and you may break the lug off in the process.
Engine: gone
Transmission: gone
Axle/Gears: gone
yup. basically. you need a nut extractor. you put that on hammer it on and use an impact gun to remove it. just as 86ta said
Engine: 5.7 L98
thank you guys, I didn't know they sold such a beast, so I'm off to the local parts store to see if they stock them...
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
There are special helix type sockets for removing stripped bolts/nuts, youll have to hammer it on same size as bolt/nut, also use a breaker bar, but I should warn you when dealing with a stubborn lug it is very possible to break the wheel stud, but they are cheap and easy to replace, when I got my car two lugs were rusted fast, broke 2 studs getting them off.
Engine: 5.7 L98
At this point, I would rather have new brake pads on that side than miss one stud, if that did happen, you know? lol...
Engine: 3.8, 3.4
It's like a 2.50$ part that takes all of 5 min to replace, you just hammer it out of the axle, and use a lug nut to pull the new one on.
Car: 1988 firebird formula
Engine: 5.7 TPI :)
Transmission: Auto :(
Axle/Gears: 9 bolt LSD
at the very very last resort, and trust me you dont wanna have to do this, you could drill it out.ive seen it done as a last resort about twice.but def try what was stated above first, goodluck!!
if it's overtightened like that you need to replace the stud anyway,
Engine: gone
Transmission: gone
Axle/Gears: gone
good point twin_turbo. We neglected to say that..haha..
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
there like 2$ i broke 4 on the right rear tire and 3 on the left rear. i was using a 1/2 impact as that was the only way they were going to budge
