Best place to find 2 inch wheel spacers?
Old May 4, 2011 | 04:19 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Going with some 17 inch Z06 wheels so Im going to need spacers. 2 inch is what everyone says, correct?
Also a 275/40r17 tire, will it fit without issue on the fronts of the car?
Old May 4, 2011 | 06:05 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: Best place to find 2 inch wheel spacers?
ebay
Old May 6, 2011 | 09:46 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
be sure to verify the hub bore for any that you buy (unless they're not hub-centric).
IROC nominal hub bore is 2.78" which is 70.6mm.
70.3 won't fit.
"unspecified" means it's a crap shoot.
Old May 7, 2011 | 11:49 AM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
I got mine from these guys
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Old May 7, 2011 | 11:50 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Ebay. Period.
Thats were I purchased mine and they are perfect.
Old Jan 19, 2013 | 01:42 PM
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
Hey I'm trying to find a eBay seller could you guys point me out to a good one for my c6 wheels that are going to go on my 90 camaro . I need 2inch spacers just for the fronts. I don't want to pull the trigger and get the wrong ones. Thanks for the help guys
customblackbird
Aug 15, 2021 10:16 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
