Keeping Center Caps on
Old Jun 16, 2011 | 09:08 PM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Does anyone have any suggestions on how to keep from losing center caps on a 3rd Gen Camaro? The tabs don't always hold them in place and @ $8-10 each it gets expensive to keep replacing them.
Let me know.
Old Jun 16, 2011 | 09:54 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Keeping Center Caps on
Only time I lost one was when I didnt put it on right. I use a rubber mallett with a towel over the cap so put them on. When I was modding my caps. I got fiberglass resin down them and that really made the metal tabs stiff which made them really not wanna come off now. But even before I did that. They didnt come off unless I was being lazy by not putting them on properly.
Old Jun 16, 2011 | 10:18 PM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Ok. I haven't tried the mallet to put them on. I just pushed them on. I'll give it a try.
Thanks!
Old Jun 16, 2011 | 10:41 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
use a towel over them or something soft so you dont crack them, and dont hit with all your might either
Old Jun 16, 2011 | 10:45 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
are you talking about the 15" wheel center caps? or the 16"?
Old Jun 16, 2011 | 11:12 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I am talking about the 15 inch caps like these
Old Jun 16, 2011 | 11:18 PM
58mark's Avatar
those are interesting with the smooth, slightly rounded dome.
Do they have metal retaining tabs or plastic?
Old Jun 16, 2011 | 11:31 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
With just the plastic tabs they do tend to come loose.
Buy some of the metal retainers & you'll stop losing them.
Old Jun 17, 2011 | 11:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah mine have metal ones
Old Jun 17, 2011 | 11:55 PM
Car: GTA
Have you tried putting the retainer in the wheel & then the cap on the retainer?
If it is in the cap a bit too far, the retainer may not be able to hook/grip into the wheel tight enough to hold.
Or try flexing your next retainers outwards a bit so that they hold the wheel tighter?
Old Jun 18, 2011 | 12:02 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I have no problems. I wonder if the OP will come back and answer those
Old Jun 18, 2011 | 02:49 AM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Thanks for all the input. I followed Undercover 89's advice. The caps I got fit much tighter than those that I have had in the past. It took a bit to get them on even with light touches with a mallet so I should be good to go.
Thanks again guys for the help!
Old Jun 18, 2011 | 11:53 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Sweet hope you don't lose any of them!
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Scamo-2.8
May 20, 2016 07:01 PM
rh76camaro
Aug 29, 2015 11:04 AM
kah992
Aug 19, 2015 02:55 PM
