Do BBS RK's fit 3rd gens???????
Old Jul 9, 2011 | 11:40 PM
JCPerformance's Avatar
I know you need the BMW bolt pattern, but other than that what are the specs?
Fronts are 8.5" and backs are 10".....
Fit??
Pics?
Old Aug 8, 2011 | 05:55 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: Do BBS RK's fit 3rd gens???????
With proper spacers they fit.Pics of mine:
http://kuva1.kuvablogi.com/iso/img3063491.jpg
http://anttiheinonen.1g.fi/kuvat/Por..._4476.jpg/full
http://anttiheinonen.1g.fi/kuvat/Por..._4118.jpg/full
Old Aug 8, 2011 | 08:41 AM
Wow! Ok, please give me the scoop.... Are those four BMW spec 18x10's?? Also, what spacers are you using? Tire size? Thanks again.
Old Aug 8, 2011 | 09:19 AM
Twin_Turbo's Avatar
5 series spec is what you need, ETs around 20
Old Aug 8, 2011 | 09:26 AM
All 18x10, right?
Old Aug 8, 2011 | 11:12 AM
Twin_Turbo's Avatar
yes
Old Aug 17, 2011 | 01:53 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
That's looking pretty good.
Old Sep 27, 2011 | 07:49 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
whats the width of the front and rear? rear is 10 right? what about the front. and whats the off set?
Old Oct 3, 2011 | 04:02 AM
z 28 jari's Avatar
Engine: 385
front 8.5x18 et13 245/40R18 GY gsd3
rear 10x18 et28 285/35R18 GY gsd3
Old Oct 3, 2011 | 09:57 AM
DBLTKE's Avatar
Engine: LB9, LB9
Sounds like those wheels are going to be tucked in quite a bit. Make sure to test fit them for inner wheel well clearance.
Old Apr 3, 2012 | 05:25 PM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
Z28 Jeri, What model year BMW did these wheels come off? Does your IROC have a stock 3-gen rear? Was it nessasary to use any spacers? And what does ET in the tire size mean?...is that the back spacing in metric? Thanks in advance, Steve.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Warlocksirix
Sep 3, 2015 12:26 PM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
