What Wheel Spacers Should I Get?
Car: 1985 Z28 Camaro
Engine: 385 Stroker
Axle/Gears: 4:11
What would be the best wheel spacer sizes for a set of 18x9 wheels with +34 offset and 235/50 tires. +34 offset on a 9" wide wheel would be about 6.25 backspace right?
Thanks!
Thanks!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: What Wheel Spacers Should I Get?
6.34" of BS, close enough.
i would say shoot to make the wheels zero offset, 5" of bs, so a 1.34 or closest spacer.
Engine: 385 Stroker
Axle/Gears: 4:11
Well if I had to choose between a 1.25" or 1.5", which would work best? The 1.5" spacers would make the wheels stick out farther right?
Thanks 100!
Thanks 100!
Both should work fine. you have stock brakes?
Engine: 385 Stroker
Axle/Gears: 4:11
Engine: 385 Stroker
Axle/Gears: 4:11
sounds like a plan
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
im running 17 by 9.5 with 54mm of bs up front with 275 40 17 with a 2 inch spacer up front due to my wheel resting on the lip on the front strut. rear is 18 by 10.5 with 58mm of bs and 305 35 18's. if this helps. i used 1.5 on my fronts and they didnt work like everyone told me they would. i went through 4 sets of spacers.
