315/35WR17 on back
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
315/35WR17 on back
i found Kumho V70a tires that i would like to get to my car, what wheel size (ET, backspace and wide) will i need to fit 315/35WR17 on 3rd gen with 4th gen rear-end ?
best regards
best regards
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: 315/35WR17 on back
if your running a 4th gen rear you should need no spacers. if you have a 3rd gen rear i am running a 1.5 inch spacer if that helps. 17 by 9.5 front offset is 54mm with 2in spacer and 18 by 10.5 rear is 58mm offset with 1.5. im also running 305's in rear 275's up front.
truly i tried to search threads about wheel fitment on wide tires and 4th gen rear-end and did not managed
and i'm not asking about brands as i even do not live in states and will get BMW wheels anyway, i just need to know sizes
best regards
best regards
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
My specs are:17X11,+50mm offset. 92' 3rd gen with a 95'
4th gen 10bolt.
4th gen 10bolt. Trending Topics
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
Car: 1992 Camaro
Transmission: t-5
Car: 82 Z28
Transmission: t-56
Car: 1992 Camaro
Transmission: t-5
Car: 82 Z28
Transmission: t-56
Car: 1992 Camaro
Transmission: t-5
Car: 82 Z28
Transmission: t-56
Fronzizzle
Mar 18, 2019 08:29 PM
4th gen 10bolt.
