Picked up Some Z06 Wheels
Old Sep 20, 2011 | 10:27 PM
brando278705's Avatar
Car: 1987 Camaro IROC-Z
Engine: 5.7
Axle/Gears: 3.70
I just picked up a set of Z06 black polished wheels. They are 18 x 9.5. I am doing some research on oh wide of tires will fit under my fenders. Who has experience with this? I was looking to hopefully fit 275's in the front and 315's in the back. Any clue on this?
Old Sep 20, 2011 | 10:35 PM
Engine: 5.7
Axle/Gears: 3.70
Re: Picked up Some Z06 Wheels
oh yeah, and I have spacers obviously to make these fit. I think they're 2.5" spacers
Old Sep 21, 2011 | 08:10 AM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
I run 2" spacers on mine
fronts are 275/35's and ive got 285/35 out back with plenty of room
Old Sep 21, 2011 | 10:44 AM
Engine: 5.7
Axle/Gears: 3.70
Awesome, thanks a lot, I think that size look real good on there. What type of tires do you have on there? Do you like them? I was thinking about going with some Nitto NT555RII's of the Toyo Proxies RA1's There pricey but hopefully will be worth it.
Old Sep 21, 2011 | 04:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a 315 is not a good fit on those wheels, they should be wider for that.
Old Sep 21, 2011 | 04:55 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
285 max on 9.5 rim....
Old Sep 21, 2011 | 06:56 PM
Engine: 5.7
Axle/Gears: 3.70
My buddy has a 9" wheel and he's got 315's on the rear of his, takes it to the strip and everything, never had a problem.. Hmm. Thats why I was asking tho, 315's seemed a little too big for the rim width. Thanks guys.
Old Sep 21, 2011 | 10:26 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
fronts are hankooks, alway been a fan and never any trouble
backs are MICHELIN PILOT SPORT's i gt off a corvette and there a nice street tire.
Old Sep 21, 2011 | 10:48 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
check the vette wheel post. there is alot of info on there that will help. on a 9'' wheel 285's would be max. im running 275's on 17by 9.5 and 305's on 18 by 10.5.Name:  camaroparkinglot.jpg
Old Sep 21, 2011 | 11:48 PM
Engine: 5.7
Axle/Gears: 3.70
Thanks, I have hankooks on the original wheels that are on now. I haven't had too much problems. They started cracking pretty quickly though it seemed to me.
Thanks a lot I will go check it out.
Old Sep 22, 2011 | 07:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
but what size wheel is it? 315 is meaningless without the wheel diameter and aspect ratio.
im sure you can squeeze a 315 on a 17x9 wheel, but that doesnt mean its recommended, or correct.
Old Sep 23, 2011 | 11:32 AM
Engine: 5.7
Axle/Gears: 3.70
Yeah it is a 17 x 9 wheel
I think he said the aspect ratio was 45. But I am not for certain. Ill have to check and get back to you.
Old Sep 27, 2011 | 02:12 PM
Engine: 5.7
Axle/Gears: 3.70
Just checked and the aspect ratio is 45.
Old Sep 30, 2011 | 11:20 AM
Engine: 5.7
Axle/Gears: 3.70
I decided I want to pick up a set of Toyo Proxies RA1. There mighty pricey but hopefully be well worth it. Heres the link:
http://toyotires.com/tire/pattern/proxes-ra1
1992rs/ss
Jan 31, 2025 05:10 PM
Amillionoh7
May 24, 2020 08:01 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
