Take a look and tell me what you think!
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
I am look at install these rims on my car. Do you think they will look good? They are a 18x9.5 with 54 offset and 7.38 back spacing. I am also wondering what size spacers I should use? I was think 2" spaces. Please let me know what you think and what size adaptors I should use! Thanks
Car: 1987 IROC Z / 1999 Suburban 2WD
Engine: Lingenfelter 383 / Vortec 350
Transmission: 700R4 / Built 4L65E
Axle/Gears: Stock / 4.56 Locker
Re: Take a look and tell me what you think!
I think those would look pretty sick on your car. 2 inch spacers.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I would look to see if you can buy those or something similar, if your attached to that style, in a size that doesn't require spacers to put them on.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Personally I like the car the way it is..... it looks very nice.
I would not change them.
If you must change wheels, mock up them with some cheap spacers & try to get the wheels inward as much as possible so they do not stick out on the front.
You can use a few small pieces of tubing the tightly fits over the wheel studs & a few stacks of washers to mock them up.
Then buy a good set of spacers in the exact size needed. You may be able to run much less spacer with 18's, maybe 1.5" to 1.75" depending on the inner wheel barrel shape. The 18's give much more tie rod clearance than smaller wheels. Your tightest clearance may be between the strut & the wheel.
You asked us if we think black rims will look good on your car, so I'll tell you. No, I don't like all black rims, especially on Camaros. On some Camaros a brushed gray works, but only on a very few. I don't understand this infatuation with all black rims nowadays. I think you'd be better off keeping the rims you have now and lowering it. Get a better stance not a rim that rice burners like.
Car: 1992 Camaro RS
Engine: L98 5.7 350
In his defense it's not really an all black rim, it has the high polished lip. Same thing my Z06 wheels have. I say go for it, those wheels will look great on your car.
Don't get me wrong though, the stockers are awesome too but I'm a sucker for vette wheels on 3rd gens!
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Rims look Good, 2" spacers would be perfect. I actually like the black inside with the lip polished. I personally prefer polished or powdercoated over crome anything.
COTM Editor
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
how much and size adapters? They look sick.
Engine: 5.7 Liter
600 for wheel 700 for tires and 2" spacers right now but I am switching to a ls1 rear!
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
looking good
Car: NissanGTS-T, Nissan350z, 89IROC
Engine: 350ci
Transmission: TH700 4 speed automatic
Axle/Gears: 2.77
The black ties in with your stripe,... wonder what 19"s would look like?
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
What tire size did you use on the fronts
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
