Can't afford tires yet so I had the wheels photoshopped
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Can't afford tires yet so I had the wheels photoshopped
I vote neither. Paint them orange to match or just the lip to match.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
This is the pic of the actual wheels I have,
Car: 1971 Camaro
Engine: 427
One of the best features of these wheels is they do not require spacers!
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i like the quality of the photchop in the first pic, so thats why i looks better. but the actual wheels in the second pic i think are better.
Car: 1971 Camaro
Engine: 427
Fronts are 18x8.5 with 13mm offset
rear. Are 18x9.5 with 15mm offset.
Fits without spacers. But front will not fit over the center hub, had to have front wheels machinemd for clearence.
Wheels are for a BMW and have the 5x120 bolt pattern, which some say in not a good idea to run on our cars.
They are stern hyermesh II
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Car: 1971 Camaro
Engine: 427
They are not forged
. I am not sure what sort of process was used to enlarge the hub. I am aware of the cap need. I am swapping to c5 brakes so those set the wheel oug a little more as well.
. I am not sure what sort of process was used to enlarge the hub. I am aware of the cap need. I am swapping to c5 brakes so those set the wheel oug a little more as well. Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
explain this theory? just curios, since i see no way properly machining the inner hub larger can hurt? Obviously going to far is bad, or opening the hole with an ax and making sharp edges that will become stress risers, but just enough to make them fit and preferably be hub centric can be bad can it?
Car: 1971 Camaro
Engine: 427
Hard to explain buy it wasn't even machined all the way through, most of the hub hole was large enough, but the was a step towards the outer side of the wheel that made the hoke smaller and allowed the center cap to snap on. The wheel, this had to be machined out, probably 1/2" of material on a a total thickness of about 2 1/2" of wheel hub thickness.
I will try and get some pics up at some point.
Car: 1971 Camaro
Engine: 427
Here is the unmachined wheel.
here is the machined wheel
front view unmachined
machined
machined
Car: 1971 Camaro
Engine: 427
Can you explain this to me as well? I certianly don't want a front wheel failing on me.
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
That wheel will be just fine
COTM Editor
Car: 1985 IROC-Z
Not soon enough! haha
The new rubber has been stacked up in the garage waiting for the wheels. Right now I am in week 6 of the order....Driver's said it would be probably 8 weeks when I ordered them...I'll be happy if they get here before mid December.
And yes any wheel failure is going to be catastrophic, so check your wheels all the time for cracks around the hub area.
Car: 1971 Camaro
Engine: 427
Paul, did you look at my pics of the machining done? What do you think?
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Blaze, wheels looks great. My old wheels where Generic wheels also dont let them hate, lol.
406tpi, Cant wait for your new wheels also... All we need is like Ram-Airs Red Camaro and we could do Red Whit and Blue! LOL
COTM Editor
OK.... back to completely safe machined wheels
Car: 1985 IROC-Z
Haha...thanks guys...just got word today that they will most likely ship the day before Thanksgiving!! I can't wait to see what these things are actually going to look like.
Car: 1991 Firebird
Engine: 3.1L V6
This is the exact same problem I have if I want to put my rear wheels on the front of my car to have 10.5" all the way around the car. I have 18x9" on the front of my car with a 1.25" spacer. Without the spacer, to fit the 18x10.5" wheels i would need to do this machining.
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
those wheels are going to look awesome.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Im a fan, Im a bit biased towards bronze wheels though!
Car: NissanGTS-T, Nissan350z, 89IROC
Engine: 350ci
Transmission: TH700 4 speed automatic
Axle/Gears: 2.77
Is there a member who could lend their Photoshop skills for other members who have no clue how too.
It would be great if I could have something matched up,... I have no idea if this is easy or hard to do.
Car: GTA
Engine: 350ci
Axle/Gears: 2.77
Cheers BlackenedBird, thanks mate!
I will check it out.
