need help with prostar wheels
Old Dec 14, 2011 | 11:49 AM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
im in the market in buying some prostar wheels from summit or also the summit brand wheels i just dnt know if they will bolt on directly to my car. i know our bolt pattern is 5 x4.75 but i just dnt know when it says about the back spacing inches.?? i really need help on this. i dnt wanna put that much of a skinny tire on the front and i want a nice wide tire in the back but not to wide that itll rub im gonna be doing the sportline lowering springs all around so if u guys can give me an idea of how it will look or what i can go with would be great thanks in advance
Old Dec 27, 2011 | 09:35 AM
robg91z's Avatar
Engine: 350ci TPI
Re: need help with prostar wheels
Will a 5.5 backspacing all around be good ? Or is it to much? Will i need some sort of spacers?
Old Jan 14, 2012 | 09:27 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
neutral backspace on these cars. 15x8 4.5 backspace i run a 15x10 5.5 backspace depending on the tire you run you may need to do some inner fender mods.. im running 295-65 hoosier drs.
Old Jan 15, 2012 | 11:27 AM
robg91z's Avatar
Engine: 350ci TPI
What about with a 4th gen rear cuz i have the swap
Old Jan 15, 2012 | 11:52 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
15x8 with 5.5bs or 15x10 with 7.5 bs on the rear, then a nice m/t drag radial, perhaps a 275/50 or 275/60 if you want a taller tire
for the front I'd rock out a 15x5 with a 195ish tire up there. Unless you want to run a big front tire, but then pro stars don't look right. Needs the big/little look, otherwise check out some other designs, the price of 17" rims has really dropped as well if you're just going for looks not added traction
Old Feb 13, 2012 | 09:20 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
With the 4th gen rear and 15x10 wheels, what tire size would work well without rubbing? Im guessing the wider wheel will cause the tires to stick out past the fenders which would limit the diameter.
I heard with the 8" wheel you could still mount up to a 10.5" slick. Shouldnt that be plenty for most street/strip cars? If so can you recommend a tire size?
I am wanting to find a tire/wheel combination I can take with me to the track and slap them on. I have always liked the prostars if I could find a set cheap enough. If not atleast I will have a wheel size and tire size to look for.
Old Feb 20, 2012 | 12:07 AM
xpndbl3's Avatar
Car: 1984 Z28
at your power level a 26x10 ET drag stiff sidewall would be a good choice. You might need to roll the quarter panel lip and beat the front inner lower wheelwell a little, depends how much room you have. I'd run the 10" rim, it'll flatten out the tread of the tire and work better overall and be more stable than a narrower rim.
Old Feb 20, 2012 | 12:08 AM
robg91z's Avatar
Engine: 350ci TPI
The 15x8 with 5.5 backspacing seems ok for me . I just dnt want the wheels to sick out the fenders with my 4th gen rear end. This shouldnt happen right? And what backspacing for the front wheels? 15x5 is good but what backspacing?
Old Feb 20, 2012 | 07:45 PM
xpndbl3's Avatar
Car: 1984 Z28
wheels won't stick out any further with the 10" rims, but the tires will sit flatter for the tread area. I wouldn't run a 26x10 slick on a 8" rim either, it'll bulge out pretty bad. Any backspacing is fine for the front, since stock is 4.5"
Old Feb 21, 2012 | 11:50 PM
robg91z's Avatar
Engine: 350ci TPI
I could only find 15x4 with a 1.75 backspacing. Will this be good or will i have any problems? Im just really worried about the rear i dnt want the tires to stick out to much cuz of my 4th gen rear end . My stock 91 rims stick out and idnt really like the look so hopefully this doesnt happen. If i run the rears with a 15x10 will they run anywhere? Either the inside or out? Just trying to get this right before i place my order. Im going with summits warrior rt wheels
Old Feb 22, 2012 | 11:01 AM
3rdgenmaro's Avatar
Car: 88 IROC
be sure to post pictures and specs whenever you do get them.
Old Feb 22, 2012 | 06:25 PM
robg91z's Avatar
Engine: 350ci TPI
Yes sir i will
Old Feb 22, 2012 | 09:14 PM
xpndbl3's Avatar
Car: 1984 Z28
fronts are fine, i think i ran a little more backspacing but that won't be an issue for ya. The rears might need some clearancing to fit. Depends car to car just get 7.5bs with a 4th gen rear. If it has ls1 brakes you will have to grind a ton off the calipers to make them fit. Lt1 brakes need a little less grinding, but still need it. Brakes are just that big.
Old Feb 22, 2012 | 11:49 PM
robg91z's Avatar
Engine: 350ci TPI
Nice thanks for the help man! Will post pics of my set up
Old Jun 26, 2013 | 06:41 PM
camaroman83's Avatar
does any body have pictures of 15x4 inch rims i want 15x4 inch rims for my daily driver would that be to skinny what about 15x6 can anybody help?
Old Jul 19, 2014 | 12:21 AM
robg91z's Avatar
Engine: 350ci TPI
Sorry old thread but barely purchasing wheels. Will 15x4 with 1.75 backspacing for front and 15x10 with 6.50 on rear fit good with my 4thgen rear? Thanks
Old Jul 19, 2014 | 02:13 PM
robg91z's Avatar
Engine: 350ci TPI
or will the 15x8 on 5.5 rear backspacing work. i have 4th gen rear!! i don't want to rub on the fenders thanks!!
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
