89 IROC rims?
Old Mar 21, 2012 | 10:38 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
89 IROC rims?
I'm pretty sure I'm on the right track here, but just wanted to verify that the rims I that I am in the process of refinishing are off a 89 IROC? I'm looking into tires and just wanted to verify that I am looking for the right size. From what I read in my searches I can go with 245/50R16 all the way around or do 245/50R16 up front and 255/50R16 in the back. I shouldn't have any issues putting these on a 90 RS right?
Any suggestion on if I should go the same all around or staggered?
Old Mar 21, 2012 | 10:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 89 IROC rims?
88-90. These did come in 15's as well as 16's, so verify the size. They will fit your RS.
JamesC
Old Mar 26, 2012 | 11:06 AM
mgilorma's Avatar
Car: 90 RS
Re: 89 IROC rims?
I verified they are 16" rims. Still not sure if I should go with the 255s on the back or just do 245s all the way around?
Anybody running the staggered setup?
Old Mar 27, 2012 | 10:36 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 89 IROC rims?
The selection for 255/50/16's had dwindled to almost nothing. You can still find some decent tires in that size, but they're all old stock, not much is actually made new in that size anymore.
Edit:
It appears BFG has their new G-Force Sport Comp 2's in that size... that's pretty much your only option unless you want to run non DOT slicks/race tires.
Old Mar 27, 2012 | 11:37 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: 89 IROC rims?
I've got the same wheels and am about to get a set of Kumho KU31 245/50/16 tyres.
I thought about getting 255/50/16 on the back, but figure they will be a fraction taller and get more side wall flex.
Old Mar 27, 2012 | 11:42 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: 89 IROC rims?
still waiting on my 255/50/16 drag radials. i believe 245 is the stock size. almost every car will give you the stock tire size if you open the drivers door and read the sticker, if its still there.
Old Mar 27, 2012 | 09:29 PM
mgilorma's Avatar
Car: 90 RS
Re: 89 IROC rims?
245/50/16 is the stock size, just wondering how many people run the 255s on the back
Old Mar 28, 2012 | 02:27 AM
peterc005's Avatar
Transmission: T700
Re: 89 IROC rims?
+1 interested in running stock 16 * 8 IROC rims with 245/50 front and 255/50 or 265/45 rear.
Would like a wider tyre in the rear to fill out the guard, but worried that handling will suffer due to additional side wall flex.
Old Apr 13, 2012 | 01:52 PM
mgilorma's Avatar
Car: 90 RS
Re: 89 IROC rims?
Just ordered a set of 245/50/15s for the front and 255/50/15s for the back. Went with the BFGoodrich Sport Comp2s. The tires should be here next week. Still have 20-30 hours of work left on the rims before I can get them mounted. I will update with pics once I get them on the car!
Old May 10, 2012 | 08:28 AM
mgilorma's Avatar
Car: 90 RS
Re: 89 IROC rims?
Got the tires mounted this week and finally put them on last night! I love it! Glad I went with the 255s on the back. The rim and tire combo just fill out the wheel wells so much better!
Attached Thumbnails 89 IROC rims?-2012-05-09-252017.58.04.jpg   89 IROC rims?-2012-05-09-252019.06.12.jpg   89 IROC rims?-2012-05-09-252019.06.29.jpg
Old May 10, 2012 | 08:31 AM
mgilorma's Avatar
Car: 90 RS
Re: 89 IROC rims?
Fronts - old vs new
Attached Thumbnails 89 IROC rims?-2012-05-09-252018.09.34.jpg   89 IROC rims?-2012-05-09-252018.08.57.jpg
Old May 10, 2012 | 08:33 AM
mgilorma's Avatar
Car: 90 RS
Re: 89 IROC rims?
Rears - old vs new
Attached Thumbnails 89 IROC rims?-2012-05-09-252018.16.49.jpg   89 IROC rims?-2012-05-09-252018.16.24.jpg
Old May 10, 2012 | 07:48 PM
adamemerson's Avatar
Car: 96 Z28 & 89 RS
Engine: Lt1 & 383 Stroker
Transmission: 4l60e & t5-5speed
Re: 89 IROC rims?
Nice, They look good on your car
Old May 10, 2012 | 08:55 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: 89 IROC rims?
You could add more air if you felt it was needed to stiffen the side wall.
Old May 10, 2012 | 09:05 PM
peterc005's Avatar
Transmission: T700
Re: 89 IROC rims?
Thanks for the pictures, look good.
Old Feb 25, 2013 | 01:24 PM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Re: 89 IROC rims?
Where can u refinish these rims in California ?
Old Feb 28, 2013 | 03:56 PM
c10freak87's Avatar
Car: 88 IROC Camaro
Engine: 305 TBI
Re: 89 IROC rims?
those look great man
Old Mar 1, 2013 | 09:36 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: 89 IROC rims?
One more thing to consider if you want that wider look in the rear. All the 16" IROC and TA PW7 have a front and a rear wheel The offset for the fronts are 16mm deeper. Now on the IROC wheels you don't notice the offset differance near as much as you do on the TA PW7's since the IROC's do not have a lip/dish to them. What I did on my TA was get a set of 1/4" spacer for the front and moved the fronts to the rear and the rears to the front and it's looks much better and has a wider stace out back. I'm running 245/50/16's all around. If you put the front's on the rear and went with the 255's out back the stance would be sweet.
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
