help please.. fitment issues..
Old May 3, 2012 | 04:46 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
I think i did this backwards..
I actually came up on a great deal..
I purchased a set of Drifz Venoms
they are 5x112 and 5x120 (according to the internet)
Hub bore - 74.1
Offset - 35
Do I do as I would for 4th gen wheels..?
Old May 3, 2012 | 05:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: help please.. fitment issues..
i assume the offset is positive? without the width, i cant tellyou much more, but you will most likely need spacers to fit them. the width of the spacers has a lot to do with the width and the final BS of the wheel. So dont just run out and buy 2" spacers.
Old May 3, 2012 | 06:06 PM
88 Z-ROC's Avatar
18x8 front 18x9.5
Old May 3, 2012 | 06:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
both have teh same offset?
Old May 3, 2012 | 06:18 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Originally Posted by 88 Z-ROC
.....they are 5x112 and 5x120 (according to the internet)
I hope you can actually find the dual lug pattern adapters (Chevy pattern to those patterns) that you will need to run those wheels.
I'm wondering if you will have to have them custom made.....
Old May 3, 2012 | 06:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the 5x120 will "work" by some peoples standards (not mine) with the 5x4.75 chevy pattern.
im sure the correct adapters can be had, and would be the ideal solution. Probably custom order, but worth the effort indeed
Old May 3, 2012 | 06:45 PM
88 Z-ROC's Avatar
aw man.. i didnt wanna hear that..
I actually set i rim on thw rear but didnt have the lugs..
Im also going by the internet.. how can i measure the actual rim
Old May 3, 2012 | 06:48 PM
88 Z-ROC's Avatar
Wow I misspelled a few words..
Anybody know where i can order. The custom adapters
Old May 3, 2012 | 06:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
these guys should do custom work
http://www.ezaccessory.com/Billet_Wh...pters_s/25.htm
Old May 3, 2012 | 07:40 PM
88 Z-ROC's Avatar
Thank you to all.
Old May 4, 2012 | 04:00 PM
88 Z-ROC's Avatar
How do I determine the thickness of the adapter needed..?
I examined the wheels yesterday and they read as follows..
18x8.5 front 5x112/120 (dual bolt pattern) 35mm
18x9.5 rear - 35mm
I dont understand how to do the math for this..
Old May 4, 2012 | 04:04 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Get a tape measure and a strait edge, and start measuring where you want the wheel/tire to sit, and measure the mounting surface of the wheel and hub.
Old May 4, 2012 | 04:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
If you have the wheels, jack up the car, take a wheel off, lower the car back.to.stock.height, place the new wheel in the wheel.well where you want it and measure back to the hub
Old May 4, 2012 | 04:50 PM
88 Z-ROC's Avatar
Easy as pie..
LMAO.. I dont know y I didnt think of that..
I thought there was some type scientific method..
Sweet..
Old May 4, 2012 | 08:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Easy as pie..
Sweet..
There are ways to figure it out using the maths, but sometimes its easier to use your eyes and a tapemeasure. That way you can see what's really happening and how.parts interact.
z 28 jari
Sep 14, 2021 10:03 PM
Fronzizzle
Feb 9, 2017 09:31 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
