Help with C6 Z06 Rim fitment (yes, I've searched)
Old May 6, 2012 | 10:39 PM
86tashawn's Avatar
Car: 2001 Jeep Wrangler 1986 trans am
I have c6 z06 repro rims
Rears fit perfect with spacers
Fronts a whole other nightmare.
Fronts are 17x9.5 with +54 offset
Wheel doesn't even go on all the way and hits shock even with 2.25" adapter on it? Can anyone help me with this?
And yes I've searched high and low for about a week now on multiple forums to find something to help me and I've come up with nothing
Thanks for the help
Shawn
Old May 6, 2012 | 10:43 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Help with C6 Z06 Rim fitment (yes, I've searched)
You positive they are 54mm? Use a ruler & double check them, regardless.
http://www.skulte.com/adapterfaq.html
Old May 6, 2012 | 11:51 PM
87350IROC's Avatar
Car: 87' IROC
A wide 17" causes all kinds of problems. First check to see if the rim is hitting the steering tie rod.
With your spacer that is about a 5" BS wheel. Stock is 4.5" BS. You should not have any issues with strut clearance. I agree, measure that wheel and get the actual back space.
Old May 7, 2012 | 11:08 AM
86tashawn's Avatar
Just measured and remeasured 3 times, 7.25" of backspacing
And I'll check again what exactly the tire was hitting but I'm pretty sure it was strut.
Old Jul 11, 2012 | 10:45 PM
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
im having the same issue i got ls1 brakes and a 1.75 adapters on and still the hit the tie rodes offset 54 and backspacing is 7.38
Old Jul 11, 2012 | 11:26 PM
87350IROC's Avatar
Car: 87' IROC
These are 17's? If so that is really not that surprising at all. With your spacers, that is a 5.625" BS wheel. That is 1.125" more than stock. And in most cases I believe the 17's are not big enough to clear the tie rods.
Here is a picture from a user here of 17" wheels with 4.75" BS. Not much extra clearance there.
Old Jul 12, 2012 | 12:07 AM
0078red1's Avatar
Car: 1990 camaro RS
so is there any way to fix it and yes there 17s c6 wheels
Old Jul 12, 2012 | 09:18 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
CTW Motorsports wheels are 5" backspace and do not hit either the struts (Bilsteins) or the tie rod end. I do have Baer brakes on the front, which bring the front wheels out a tad, but it would still clear even with stock brakes.
If the strut hits, you only need to grind it down to clear, tie rod end can be ground down in most cases too...
54mm = 2.126", which with a 2.25" spacer should clear decent, maybe needing a little massage.
Old Jul 12, 2012 | 10:17 AM
0078red1's Avatar
Car: 1990 camaro RS
Dang im going to need to buy another .25 spacer then oh well trial and error
Old Jul 12, 2012 | 10:36 AM
87350IROC's Avatar
Car: 87' IROC
No more trial and error. Why don't you stack up 1/4" of washers or wood or whatever behind to wheels to make sure it will fit.
Old Jul 12, 2012 | 11:00 AM
0078red1's Avatar
Car: 1990 camaro RS
The only reason why I don't do that is because it only hits when I drive not when its in park. When its in park there's space inbetween the tie rods and wheels but when driving they hit
Old Jul 14, 2012 | 10:19 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Yeah driving with washer spacers would not be a good thing to try.
Fronzizzle
Feb 9, 2017 09:31 AM
Chad Speier
Sep 24, 2015 12:32 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
