will these rims fit on my car?!?!?!?!?
Old Jun 27, 2012 | 12:36 AM
jb1289610's Avatar
ok guys. so i got a set of lorinser rims off of a friend of mine for 50 bucks (theyre worth around 1400). they are lorinser 3 piece racing rims are are very cool looking. but i need to know if they will work with an iroc. they are originally meant for a mercedes benz BUT, have had other holes put in to fit the camaro bolt pattern (he had them on a 4th gen). here are the specs.
Rim diameter: 16
rim width: 8
offset: 35
will these things fit in that body with little or no rubbing? will they fit in there at all? any help would be nice. thanks. I attached pics as well.
Old Jun 27, 2012 | 12:37 AM
jb1289610's Avatar
Re: will these rims fit on my car?!?!?!?!?
by the way. i drive an 84 z28
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
With the right sized spacers, yes. Look for a wheel with close to the same offset as yours.
http://www.skulte.com/adapterfaq.html
Old Jun 27, 2012 | 01:36 AM
Car: GTA
https://www.thirdgen.org/forums/sout...acers-4-a.html
Old Jun 27, 2012 | 11:55 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
If the bolt pattern is right, you would need something around a 35mm spacer to get the wheel back to zero offset, which is what you want for the 3rd gen.
Old Jul 2, 2012 | 09:09 PM
1992PonFirebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 400 sbc
Axle/Gears: 3.73 Limited-Slip
I had a question too. I am looking at new rims for my 1992 Firebird. The rims are 18x8.5 in the front and 18x9.5 in the back with an offset of 40. If I did get these do you know would they rub on the fenders or anything? I would get 275 on the back and 215 in the front. I have to get 1.5 in spacers for the front and 1 in spacers for the back to even out the offset but I just don't want to buy the rims and then the tires and the tires rub on the fenders when I turn or rub on the rear. Please just let me know what you think
Old Dec 5, 2012 | 09:36 PM
jb1289610's Avatar
ive heard bad things about wheel spacers. and im deffinately going to race my car. so i would need an option that is durable, reliable, and works good. and i just dont know if spacers will handle the stress. are there any other options? i really want these rims on my car.
Old Dec 6, 2012 | 01:03 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Don't buy the cheap, Chinese ones from ebay and you'll be fine. Try a place like this: http://www.motorsport-tech.com/
Old Dec 7, 2012 | 01:30 AM
jb1289610's Avatar
and these for sure wont mess up or fall off? im very worried about using spacers. they will be taking a beating. hard cornering. high speeds. the works.
Old Dec 7, 2012 | 10:23 AM
Car: GTA
I am of the firm belief of buying wheels that fit right & not adding extra weight from adapters plus running double the lug nuts & double the wheel studs.
Not sure of racing sanctioning bodies rules regarding wheel adapters but I know that I would never use them for autocross or road racing because of the lateral g-loads in cornering nor would I use them on the rear in drag racing because of the g-loads in launches.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Exxon Limited
Aug 9, 2015 08:13 PM
antares57
Aug 6, 2015 07:47 AM
