5 inch backspace with slicks
Old Sep 6, 2012 | 02:40 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
Guys,
It's time to go drag racing and I need some slicks. Found these on Craigslist in Atlanta and they are 2 miles from me. it seems that 5 inches of backspace is about right and these might fit. is 26x10 the right size for some friday night drags at Atlanta Motor Speedway or Atlanta dragway?
I have adjustable rear springs so I can jack them up to get enough clearance.
what say you? I was thinking of offering him $250 cash money.
http://atlanta.craigslist.org/atl/pts/3192287598.html
Old Sep 6, 2012 | 05:03 PM
87350IROC's Avatar
Car: 87' IROC
Re: 5 inch backspace with slicks
Originally Posted by BrianChevy
Guys,
5" BS 10" wheel will stick out from the fenders.
Old Sep 6, 2012 | 05:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its an 8.5" wheel apparently, i think that will be pretty good as far as fitment.
Old Sep 6, 2012 | 11:03 PM
87350IROC's Avatar
Car: 87' IROC
Hmmm, I clearly don't know the size convention for drag slicks.
Agreed, that fitment sounds good on a 8.5" wheel.
Old Sep 7, 2012 | 12:34 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I don't know if you have run slicks before but if not you might want to think about a support cover.
= http://www.jegs.com/i/LPW/619/301-7.5G/10002/-1
Old Sep 7, 2012 | 03:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
The add clearly says they are 8.5" wheels, no gypsy magic here, lol.
Old Sep 7, 2012 | 04:39 PM
87350IROC's Avatar
Car: 87' IROC
Yup, got it. I read the 26x10 dimension in the OP's message as the required wheel width. I guess that is the tread width. I didn't bother to read the ad.
Old Sep 7, 2012 | 04:49 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
What back spacing would he need to get a 10" wheel with a 10" wide slick in his wheel well. 6.5"?
Old Sep 7, 2012 | 04:52 PM
87350IROC's Avatar
Car: 87' IROC
6.0 - 6.5" should work well. I went with around 6 3/8".
Old Sep 7, 2012 | 04:55 PM
Edwardgp's Avatar
Engine: 454-350
Great is your wheel width 10"?
Old Sep 7, 2012 | 05:12 PM
87350IROC's Avatar
Car: 87' IROC
Yes. That would be a silly BS for anything but a 10.
Old Sep 7, 2012 | 05:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the diameter of the wheel has great imortance here. A 18 or 19" wheel for instance will almost fit 6.5" of bs without anymore than a few taps with a hammer. a 15 or 16 is a different story all together and 6.5" of bs will need a lot more work to fit.
a 15x10 with 6" of bs is a pretty good fit, but its not a common offset
Old Sep 7, 2012 | 05:40 PM
87350IROC's Avatar
Car: 87' IROC
Phil you are on your game as usual.
Good point. It also depends on ride height. At my ride height with 19's the bump stop actually rides inside the wheel. Not the case with smaller wheels or a much higher ride height. I don't recall, there may be other things in the way as well. I can grab a picture of my empty wheel well tonight.
Old Sep 7, 2012 | 06:09 PM
Edwardgp's Avatar
Engine: 454-350
I am pretty sure there will be some cutting and welding.
Old Sep 7, 2012 | 06:23 PM
87350IROC's Avatar
Car: 87' IROC
As pointed out it will really depend on a number of factors.
Wheel size
Backspace
Ride height
Linson
Oct 24, 2025 02:00 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
