Need new Track wheels 17 or 18
Old Oct 24, 2012 | 09:31 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
My track tires are worn out and i've been thinking about getting a larger set of wheels- i like the look of the vette wheels, but it would be nice to get wheels that don't require spacers- Such as the ROH zs rims. For track wheels, i don't need anything quite as shiney or expensive as new ROH rims. Are there other options out there that fit our cars in 17's or 18's? Thanks
Old Oct 24, 2012 | 10:57 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Need new Track wheels 17 or 18
Check out CTW Motorsports wheels. 17" x 9.5" and need no spacers to fit - strong and light too!
Old Oct 24, 2012 | 10:58 PM
87350IROC's Avatar
Car: 87' IROC
In my opinion, the CTW wheels seem to suit your needs. Lightweight 17x9.5 with no spacers required and at a fair price with great brake clearance.
http://ctw-motorsports.com/products/
EDIT: Paul beat me to it.
Old Oct 25, 2012 | 07:28 AM
hotrodln's Avatar
Engine: Lt1 in IROC
hey thanks- they look good, but they are 1200 a set. I might just do it anyway. thanks for the tips!
Old Oct 25, 2012 | 02:49 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
There's aren't really any quality wheels that will be cheaper than that especially in those sizes with the exception of replicas or knock-offs. Wheels and tires cost a lot of money. That's just a fact that people need to realize.
Old Oct 25, 2012 | 03:11 PM
hotrodln's Avatar
Engine: Lt1 in IROC
I hear ya! those wheels may end up being the best deal- i've just started searching. i got a set of aluminum rims for our chevy cruze for winter tires from the tire rack last week- they were about 100 bucks each. Good looking wheels too. probably made in china
Old Oct 25, 2012 | 03:37 PM
paul_huryk's Avatar
They are actually $1,125 plus shipping for a set:
http://www.ctw-motorsports.com/purchase/
Be wary of cheap knockoff wheels - many of them are not DOT tested or compliant and may be prone to failure than ones that passed the tests.
275-40-17 tires start at about $120 each and there are a lot of excellent summer tires in the $170 to $190 range.
Old Oct 25, 2012 | 03:52 PM
hotrodln's Avatar
Engine: Lt1 in IROC
Those wheels certainly look good. has anybody used them?
Old Oct 25, 2012 | 05:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Keep in mind, since those wheels don't need spacers, that's about 200 bux or more for good 2" spacers for your typical vette wheel, and another set of lugnuts you don't need to buy.
Other option would be to try and fine a set of ronal r15's, but they will likely cost more and are a few pounds heavier.
Brake clearance was mentioned, those ctw wheels clear my 14" baer 6 piston brake kit. So if you plan a brake upgrade, there will be little that won't fit.
Old Oct 25, 2012 | 05:59 PM
hotrodln's Avatar
Engine: Lt1 in IROC
yeah i like the look of the vette wheels, but the spacers make me alittle queazy...this car rarely gets "cruised around"....mostly just track days...pedal to the metal, as fast as it will go! so i'll probably just get a set of these.
Old Oct 25, 2012 | 09:25 PM
paul_huryk's Avatar
Other option would be to try and fine a set of ronal r15's, but they will likely cost more and are as mentioned, those ctw wheels clear my 14" baer 6 piston brake kit. So if you plan a brake upgrade, there will be little that won't fit.
Phil is 100% correct on all points - although from what I have heard, the R15's don't have as much brake clearance as the CTW wheels and supposedly won't fit C5 brakes without spacers. They look nice though...
paul_huryk's Avatar
Call CTW direct if you have any questions or would like to order...
Old Nov 6, 2012 | 01:09 AM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
That's because you don't look hard enough. If you don't race at all, you can get buy with used tires that are dirt cheap. I am going the used corvette rims route with wheel adapters for the track and I'm not worried about it. My rims were dirt cheap also, only 200 bucks. You can't beat that.
Old Nov 6, 2012 | 01:10 AM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Oh, and some wheel adapters will come with lug nuts.
morrow
Jan 13, 2024 12:29 PM
Amillionoh7
Sep 5, 2015 11:44 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
