Tire and rim ?
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Tire and rim ?
What is the largest rim and low profile tire I can put on my 91 Firebird Convert?
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
Re: Tire and rim ?
That depends on how much modifying you want to do to your car. You can put 18s on it no problem.
Engine: 305 TBI
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Re: Tire and rim ?
You're welcome. I don't think 18" tires come in the 30 series height but they come in 35 series height and 19" tires come in 30 series height if you can swing that kind of dough for tires.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Tire and rim ?
You can get 17" to 20" wheels and tires that will offer the same overall tire diameter as stock 16" ones do. As small as a 245-45-17 to a 275-25-20 will work on the right wheel. There is a point of diminishing returns above an 18" wheel and tire - you get a much rougher ride, heavier weight, and the ability to bend wheels at will due to the small sidewalls.
Engine: 305 TBI
Re: Tire and rim ?
I want something to fill the wheel well and lower the car a bit.
Re: Tire and rim ?
But lowering the car does get rid of the tire to fender gap, which does fill up the well...
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Re: Tire and rim ?
So, going to an 18" rim with a 45 series sidewall height may make the tire taller than the one you have now.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
