Help on offset on varrstoen v3 wheels for my third gen camaro please
Old May 20, 2013 | 12:42 PM
ravekin's Avatar
Car: camaro 84 z28
Transmission: automatic
I want to mount this rims on my camaro but need help
Varrstoen specs
Front 18x8.5 35et
Rear 18x9.5 40et
I want to know if this offset the will need adapters or what would you recommend?
Old May 20, 2013 | 02:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Help on offset on varrstoen v3 wheels for my third gen camaro please
Both will need adapters, as close to 35mm thick as you can get would be best front and rear. Make sure the center bore of the adapters and of the wheels will work with the front hub of the car since its quite long. You might not be able to use the centercaps unless I'm thinking of a different wheel.
Old May 20, 2013 | 04:22 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
thats about right prob can . centercaps might fit it will be close 22mm would be the thinnest adapter
Varrstoen specs
Front 18x8.5 35et
Rear 18x9.5 40et
hmmm i wonder where you got the idea for the wheels lol
you know there 114.3 Right?
Old May 20, 2013 | 07:12 PM
ravekin's Avatar
Car: camaro 84 z28
Varrstoen v3
5x120 for BMW
Front 18x8.5 35 et / 5.55 "bs
Rear 18x9.5 40 et /6.25" bs
Cb 73.1
Directly from dealer
Old May 20, 2013 | 08:27 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Varrstoen v3
5x120 for BMW
Cb 73.1
Cool they must of just released them ? didnt see any info on website just say coming soon they look like the ES7s lol i dont know tho havent look into it
why not go 9.5 all around better grip or 9.5 -10.5 or even 10.5 all around
good luck post pics
I have the ES2
Old May 21, 2013 | 12:15 AM
ravekin's Avatar
Car: camaro 84 z28
is there any spacers that match cb and bolt pattern?
Old May 21, 2013 | 12:32 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
http://www.motorsport-tech.com/
highquality and custom i rock them !!
Old May 28, 2013 | 11:51 PM
ravekin's Avatar
Car: camaro 84 z28
they are redline.. not varrstoen
anyways the same lol
Old May 29, 2013 | 08:55 PM
ravekin's Avatar
Car: camaro 84 z28
I already have this rims, but they wont fit.. bolt pattern is the same except center bore.
My question is:
What else can I do besides buying motorsports adapters for back space..
thx
Old May 29, 2013 | 10:54 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
My question is:
thx
so exactly whats the issue ? not really giving good details
so hub doesnt fit center bore ?
Old May 30, 2013 | 12:29 AM
87350IROC's Avatar
Car: 87' IROC
My question is:
thx
5x4.75" is not the same as 5x120mm. Do your research before you determine this is safe.
Old May 30, 2013 | 11:55 AM
ravekin's Avatar
Car: camaro 84 z28
This is my research :
Front wheels adapter:5x120.7 cb 70.3 to> 5x120 cb 73.1 total spacer width around 1 3/4in
Rear wheels adapter :5x120.7 cb 70.3 to>5x120 cb 73.1 total spacer width arround 1 37/64 in
Adapter width its an aproximate, working on spacing right now ima take some pics and post em.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
