86 iroc pulls hard to the right.
Old Jun 14, 2013 | 10:09 PM
3rdgenowner's Avatar
Car: 89 camaro rs
Engine: 350 tbi
Hi guys,
My car is pulling very hard to the right and shakes under 20 mph.
Tires have plenty of chicken fat on them, but the left front tire has cupped in the center and has a small bulge, is it the tire or brake calliper? All tires have 44psi.
Should I replace the front tires?
Thank you!
Old Jun 15, 2013 | 03:20 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: 86 iroc pulls hard to the right.
sounds like a caliper to me. does the rim get hot after a short drive?
if you have a bad tire, change it before you have problems.
Old Jun 15, 2013 | 12:23 PM
Car: 89 camaro rs
Engine: 350 tbi
No the rim doesn't get hot, the tire use to be on the right front, and the car would pull hard to the left, and then I ended up putting the tire on the right to see if it would help at all, and it ended up pulling hard to the right.
Still think it's the caliper?
Old Jun 18, 2013 | 05:30 PM
827-snyWA's Avatar
Car: 88camaro
Engine: carburated 350
Transmission: th350
Axle/Gears: 3.73 posi
go get an alignment.
Old Jun 18, 2013 | 05:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by 3rdgenowner
...tires have 44psi.
What size tires are you running? The recommended pressure on my IROC OE-sized tires is 30.
JamesC
Old Jun 18, 2013 | 07:31 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
This right here tells me you have what is known as a radial pull. In other words your tires are shot. If you can rotate the front left for the front right and duplicate the pull in the opposite direction its time for new tires and a GOOD alignment. There may have been more to cause that as well such as worn suspension parts and such. But at any rate you def need new tires now.
Old Jul 2, 2013 | 04:14 PM
Car: 89 camaro rs
Engine: 350 tbi
I got new front tires guys, drives straight.
Thank you
Azrael91966669
25
Jun 20, 2017 04:04 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
