My new wheels. 17x9 & 17x10 OG San (cross-lace style)
Old 07-18-2013, 10:31 PM
Downshift's Avatar
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
Threw on a set of OG San wheels on my Z28. I had to have these wheels because I love the lip in the rear and the fact that they are a 17 x 10. I got in touch with Axis Wheels and they made it happen. I'm stoked.
The set up up front is a 17x9 +10 with a 1in spacer and rear is 17x10 +15 with an 8mm spacer.
Old 07-18-2013, 11:19 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: My new wheels. 17x9 & 17x10 OG San (cross-lace style)
Old 07-18-2013, 11:26 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Originally Posted by t-top havoc
Old 07-18-2013, 11:31 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Nice! Guess there is everyone's answer to bigger GTA wheels
You have anymore info on offset you went with?
Here is a link to the wheels http://www.axiswheels.com/view-wheel/ogsan-17-
Old 07-18-2013, 11:34 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Super Sharp!
Old 07-19-2013, 12:23 AM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Thanks!
Old 07-19-2013, 12:25 AM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Originally Posted by sack23
Super Sharp!
Thanks sack23.
Old 07-19-2013, 01:03 AM
87350IROC's Avatar
Car: 87' IROC
Those look excellent, but aren't they 5x120?
Old 07-19-2013, 07:29 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Ooh, I like them! Look great! Is is a one piece wheel?
Old 07-19-2013, 08:11 AM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Thanks! Yes, the bolt pattern is 5x120. 17" is the diameter, 9" is the width and +10 is the offset on the front. Same break down on the rear being 17" diameter, 10" width and +15 offset.
Old 07-19-2013, 08:13 AM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Bullydawg, yes it is a one piece.
Old 07-19-2013, 08:37 AM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Very nice!
Old 07-19-2013, 08:58 AM
Zed/28's Avatar
Car: 89 Z
Axle/Gears: 10 bolt 3.23
Those look awesome ! Tire sizes ft &rear ? Very nice car .
Old 07-19-2013, 09:30 AM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
235/45/17 up front.
255/40/17 in the rear.
Old 07-19-2013, 10:19 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
235/45/17 up front.
Good looking wheels and car!
I'm curious to know why you chose 235/255 tires instead of something wider?
Old 07-19-2013, 11:05 AM
IMissMy86TA's Avatar
Car: 1988 GTA 5-spd TPI
Engine: 5.0 TPI
Transmission: T-5 baby
Axle/Gears: 3.45
those truly look like GTA wheels. wow. nice!!!!
the lace pattern on many similar ones are not exact with different centers just wow
Old 07-19-2013, 02:13 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Those are the measurements that we used on the test fit as shown in the images. I will probably end up going with 245/45/17 in the front and 255/50/17 in the rear. I dont want to go too wide because I like that slightly rounded donut look at the edge of the side wall where the thread begins. Nothing streched just slightly rounded.
Old 07-19-2013, 04:03 PM
paul_huryk's Avatar
A 245-45 and a 265-40 are the perfect size combo for your wheels and desired look. Problem is that the 265 is not made in as many patterns as the 245.
Old 07-19-2013, 05:31 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Thanks for the info paul_huryk. I will look into the 265-40s.
Old 07-19-2013, 07:20 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I want those wheels but in 18". I emailed Axis today to see about having some built and to also make the outer hub fit the factory center caps. Hopefully we can work something out. I will keep everyone posted.
Old 07-19-2013, 07:27 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Yes! GTA wheels!!
Old 07-19-2013, 07:49 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Next set of wheels ^
Is it possible to order with custom offset to avoid spacers?
Is it possible to run 275 in front with 295 in rear?
The price seems fair too
Old 07-19-2013, 08:01 PM
akanitro's Avatar
If I don't get an email response from them by Tuesday, I will make some phone calls and see if they can help us out. Lets see if they can build them and what kind of pricing they are talking about. And yes, if we could do 18" or 19" even and proper offsets to avoid spacers and wider tires too would be awesome. I do want to emphasize the center hub diameter to utilize our factory center caps though and also want to find out if they can be made without the bolts at the outer ring of the wheel to the barrel area.
Old 07-19-2013, 08:04 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Yes! You've hit the nail on the head all the above would sell like crazy on tgo
Old 07-19-2013, 08:09 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I would definitely buy a set of 18s... keep us posted!
Old 07-19-2013, 08:15 PM
akanitro's Avatar
Once I find out if they can do it and how much the first set would set me back I will mention a small production build of them to see how feasible it is. The older Nissan Z car guys would jump all over these also.
Old 07-19-2013, 08:33 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
18x10 and 18x9 would be perfect for me....
Old 07-19-2013, 08:35 PM
akanitro's Avatar
I planned on using that as a bargaining chip when we get to talking about price but I cannot commit to anything. You know how people are. Everyone says hell yeah I am in 100% but when it comes to money time, everyone has an excuse. It's just what happens.
Old 07-20-2013, 12:58 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Looking nice just need some wider tires and it be perfect
They just release those the Been in the 16" size for the longest nice to see they re did there logo too
Old 07-20-2013, 09:07 PM
85_ZED28's Avatar
Car: '85 Z28
Wow great job. Those look amazing!
Old 07-20-2013, 09:54 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Thanks Zach and 85_ZED. I will definitely be going with wider tires and more side wall. Here is another image I came across.
Old 07-21-2013, 10:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If Axis can be convinced to build a set in 5x4 3/4 in the right offset, they will be very popular with the Grand National crowd.
Old 07-22-2013, 02:35 PM
akanitro's Avatar
I just spoke with Derek at Axis Wheels. Unfortunately, the 17" is the only thing they will offer out of the box. Also, no modified outer hub for factory center caps and the rivets are pressed in so there is no color change available from black to gold. He suggested I contact so custom wheel builders to meet my specifications. Sorry guys, but what we see is what they have to offer. I am still considering buying the 17" wheels as they still look a lot better on the car than the factory 16". As far as the center caps, I can have them painted black to look more stock. Anyone want to get in on a group purchase?
Old 07-22-2013, 04:09 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
I'd consider getting in on a group purchase. Someone needs to put a set of these on a GTA with 275's or wider on the rear!
Old 07-22-2013, 04:12 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Wow those rims and tires look incredible! What a head turner. A sure fire candidate for COTM
Old 07-22-2013, 05:57 PM
miamivice's Avatar
Car: 88 GTA
Wheels look great! Would love to have larger sizes that would be direct bolt ons for our cars.
Old 07-22-2013, 06:36 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
If you can find a dealer that still has them you can simply superglue the Firebird wheel center emblems to the wheel centers.
Old 07-22-2013, 07:09 PM
akanitro's Avatar
A simple sign shop that does vinyl stickers can reproduce the original WS6 emblems for a couple dollars and then just paint the silver caps flat black before putting the stickers on the face of the cap. I am definitely ordering a set for the GTA. For the money, its still a great deal on a nostalgic looking set of wheels. I am going to place an order at the first of the month. Let me know who else wants in and I can talk to Derek at Axis about a deal. Serious people though please. I don't want to commit to a multiple wheel package order that I can't stand behind. PM me if anyone is serious and wants to order a set with me.
Old 07-22-2013, 08:39 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Thanks for the compliment. I just picked up the set I'm keeping today ( in graphite) Ill post a picture in a bit. I have to give a shout out "thank you" to Axis wheels and www.cncpics.com for the networking.
Old 07-22-2013, 10:03 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Old 07-24-2013, 01:45 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
SICK!!!! very nice!!
Old 07-24-2013, 04:18 PM
  #42
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
BBS E50 and SSR mesh's are probably my favorite wheel ever...
Old 07-24-2013, 04:36 PM
  #43
Engine: 305 to 350
Axle/Gears: 10 Bolt
Im bias to the graphite lol looks clean.. Golds would look good on white
Be intresting to see how 17x10 all around would look on a lowered Formula
Old 07-24-2013, 05:29 PM
  #44
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: 5.7 TPI - LS1 Forged by LME
Transmission: 700r4 - 4L60E
Axle/Gears: 3.23 - 3.73
Just Awesome looking!
Old 07-27-2013, 02:15 AM
  #45
LSJuan0068's Avatar
Car: 1983 Chevrolet Camaro Z28
Engine: 5.7 SBC Gen1
Give the deep dish all around and we have a winner. For some reason, the side view doesnt do it for me. Still something for those wanting a option for larger crosslaces. Now I still doubt 95% of the people who always complained for 17s+ will even buy them.
Old 07-27-2013, 02:03 PM
  #46
Roostmeyer's Avatar
Axle/Gears: 3.70
Originally Posted by LSJuan0068
...For some reason, the side view doesnt do it for me... Now I still doubt 95% of the people who always complained for 17s+ will even buy them.
Is it the lack of a mirror finish? The machined finish isn't doing it for me, but stripping the clear off to fix it would mean repainting the centers and a lot more trouble than it's probably worth.
As for people still not buying them, the offset, bolt pattern, and center bore aren't right. I would run hubcentric spacers to correct the offset and center bore and hope that spacing out the wheels keeps you from breaking wheel studs after removing the wheels a few times.
Or you can correct the bolt pattern: https://www.thirdgen.org/forums/whee...t-pattern.html
Old 07-27-2013, 02:06 PM
  #47
Holmes's Avatar
Car: 1991 Camaro Rs/Z28 clone
Engine: 5.3LSX
Axle/Gears: DTS 12 Bolt 4.10
Those are stunning, definitely loving the gold on red combo
Old 07-27-2013, 07:55 PM
  #48
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
Those do look great......bout time someone made some bigger replicas
Actually a 275-40-17 is a better/exact fit size for a 17x9 wheel....(stock 4 gens w/17's have 275's on them)....
But with a 9 front and 10 rear to really get that staggered look you can do a 255-45-17 front and a 285-40-17 rear. They both are 25.94 in. tall (stock 3rd gen 16's are 25.7).....and a 285 will fit better on a 10" wheel....
check out the Nitto 555's.... http://www.nittotire.com/Tire/nt555#size
I have Boyd Codington Magnito's 17x8 F with 245-45-17 and 17x10 R 315-35-17....
just my
Old 07-27-2013, 10:08 PM
  #49
GTA777's Avatar
Car: 91 Trans Am GTA
Nice rims Downshift. Congrats.
I've been looking for bigger replica rims like these for awhile. Thinking of getting 2 17 X 10 for the rear and leaving the front with the 16s.
Old 07-29-2013, 09:38 PM
  #50
GTA777's Avatar
I always thought our rims bolt pattern were 5 X 120 and not 5 X 120.65. Due to the small variance, .65 mm, which is very small, would the rim not fit on our cars? I found a dealer in Canada who can get these for me and was about to purchase them but want to make sure these would fit.
Thanks.
Quick Reply: My new wheels. 17x9 & 17x10 OG San (cross-lace style)
