quick backspacing question
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
i wanted to know what the maximum backspacing is that you can fit on a third gen on the front and the rear without any modification to the car. can anyone help me out
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: quick backspacing question
What diameter wheel makes a big difference. What you looking into?
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Somewhere around 5.5" depending on the actual wheel. It is dependent on the shape of the inner wheel shell where it is close to the tie rod.
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I have 17x11 wheels on back with 5.5" of backspacing - they stick out. It looks like I could easily do 6" backspacing, maybe 6.5". There is a guy who ran 7" of backspace on the rear, but he had to do some massaging of the inner fender wells.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
BS from 5.25 to 5.4" will work all around - anything more and you risk hitting the tie rod ends. Unless you have a BBK that moves your track out in the front, 5.5" BS will most likely require at least a thin spacer.
Engine: Carbed 355
im looking at 17x11 american racing torque thrust II wheels for all four corners. im getting fender flares that add 1.5 inches out. since you can run 9.5 inch wheels factory with no problems or tucking issues, im just gonna add 1.5 inches to that and thats where i get the 11 from. im getting alot of numbers, but i need exacts front and rear. whats the max bs rear
Engine: Carbed 355
actually, whats the backspacing of the firehawk rims, they are 17x9.5, i can use that backspacing and just get that in 11 inch wide AR rims
Car: 89 GTA
Axle/Gears: 4.10
I have Torq 17 x 9.5" in front and 17 x 11" in rear and done extensive searching for this.
My fronts have 5" backspacing and it's a perfect fit with 275 tires. Any more backspacing and you hit the tie rod end.
My rears have 5.5" backspacing and while it clears everything in the inner fender, the 315 tires stick out of the fenders. If you want to tuck the 11 inch wheels inside the fender you need 6.5" - 7.0" backspacing and you will have to mod your inner fenders. There are many posts on this with pictures.
If you added 1.5" flares, a 5.5" backspacing 17x11 rim on the rear would work well for you. I'm pretty sure you will have issues with a front 17 x 11" rubbing badly at full lock. My 17 x 9.5" rub lightly at full lock.
Engine: Carbed 355
ill have the 1.5 inch flares on the front too. and thank you very much for the detailed info.
Engine: Carbed 355
89******bird, what is the tire size and brand of your rear tires, 315/__r__
Engine: Carbed 355
haha it sensored the word m u l l e t
Engine: Carbed 355
my car has 16x8 torque thrusts with 3.75 inch backspacing. so does that mean if i g0 6.25 backspacing, which is the max backspacing before any modification, that i can run 10.5 inch wide wheels? the 16x8's sit flush in the wheel well right now.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Car: 89 GTA
Axle/Gears: 4.10
With 10.5" you may rub the outer fender lip. I have 10" wheels with 285 tires with 6.2" backspacing and it barely clears the fender lip.
Car: 89 GTA
Axle/Gears: 4.10
Agreed. But to fit a 10.5" wheel inside the fender you will need about 6.5" backspacing, which will require some inner fender mods. 10" is about the widest you can fit without any modding. (in my opinion, but there are many on this topic)
That may be true. And it also depends on which lower control arms you have on your car. Some are wide, narrow and between. I think with a 295/35/18 tire may rub more than a 285/35/18.
Engine: Carbed 355
wait, but i have 8 inch wide wheels on it right now, and they have a 3.75 inch backspacing on them. max backspacing without any mods is 6.25 inches. 6.25-3.75= 2.5 inches. 8+2.5 is 10.5 so if my math is correct, it will fit in the fender well without any mods with a 6.25 inch backspacing
also, my wheels right now are flush with the outer fender lip, not the inner lip that folds in, beyond that. im going to roll my fenders in the rear so it wont rub the lip
