torquing front wheel spacers
Old Nov 3, 2013 | 02:51 PM
83 Crossfire TA's Avatar
Was just thinking about this, an appropriate torque setting on a lug nut keeps them from coming loose- too little they can back off, too much they can distort and/or pull through.
So how do you torque the lug nuts on the front wheel spacers, since the hubs will turn without a tire on the ground to keep it from turning? I wish this car had a line lock so I can lock the front brakes...
Old Nov 3, 2013 | 09:12 PM
ReEntry Racer's Avatar
Car: '82 TA GT1 Roadracer
Engine: ZZ4 Fast Burn 385
Transmission: TEX101A Dog Box
Axle/Gears: 3.73 4th Gen w/Auburn Racers Diff
Re: torquing front wheel spacers
I use an impact gun (pneumatic). If you don't have access to a compressed air source, then buy an electric impact. Test the setting that gets the torque you want by using it on a standard lug nut with the wheel held, then check with a good torque wrench to verify the gun setting.
Old Nov 6, 2013 | 05:51 PM
Marc 85Z28's Avatar
Use a brake pedal depressor. Don't have one? Jamb a pry bar or other tool between the front seat and brake pedal.
Old Nov 7, 2013 | 12:56 PM
I found a brake pedal depressor- one of the 3rd gen guys that lives in my neighborhood snuck out of the house to hold the brake for me...
Amillionoh7
May 24, 2020 08:01 AM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
