Installing 18" wheels, what size tires?
Old Nov 6, 2013 | 07:25 PM
CandyBrandyWine's Avatar
I just purchased 18x8 wheels tonight. I'm putting them on my 1987 Iroc with in the next week or so. What size tires should I use with this rim package? Also, should the rear tire be different from the front.
Old Nov 6, 2013 | 07:41 PM
Re: Installing 18" wheels, what size tires?
Also, I read in a post that I have to lower the vehicle. Is this true and if so how far. If it has to be lowered what method do most use and where do you buy the parts to complete the lower.
Old Nov 7, 2013 | 10:45 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You dotn have to lower the car to install different wheels. 245/40/18 is the most common fitment for that wheel size. Cant really go mch wider with that size
Old Nov 7, 2013 | 02:15 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
I have 255/35/18 on my 18x8 rims and 275/35/18 on 18x9s, imo this is perfect. lowering is not a necessity merely personal prefernece.
Old Nov 7, 2013 | 03:19 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
245-40-18 is the right size for your wheels. It gives you the same tire diameter as stock (doesn't throw off your speedo) while not being too wide for your 8" wheels.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
knight72
Aug 10, 2015 09:32 PM
