Newbie needs help, 275/35R18?
Old Apr 4, 2014 | 08:59 PM
jhev1's Avatar
Car: 1987 IROC Z28
Transmission: Rebuilt 700R4
Axle/Gears: Stock
Hey guys,
I've been lurking for a while, drooling over some cars and wishing it could be my car. Well, my time has finally come! A little back story first. I've had a 1987 IROC Z since the mid 1990's. It's been sitting in my garage for 10 years now. Before that I lugged it out to CA in 2002, then when my wife and I moved back to CT in 2003 it came back with me. All towed since right around 2001 the tranny crapped out, had it rebuilt, crapped out, rebuilt, crapped out, rinse, lather, repeat 9 (NINE!!!) times in about 3K miles and I finally just bought a new car figuring I'd fix this one up when I was rich and successful. Well that hasn't happened, but I do have a few dollars to put into it now. Not as many as I would like, but enough for a tranny, wheels, tires, exhaust and maybe, maybe a stereo. Anyway, on to my actual question.
I really love these wheels, they are almost the same as the stock but chrome and 18's. My question is will a 275/35 fit in the well? Will it need to be modified? Does anyone have any pics to share of a 275/35/18?
Oh the pic is right before I had it trailer back to CT. It looks the same now, just with ten years of dust and four flat spotted tires.
Attached Thumbnails Newbie needs help, 275/35R18?-headon-1-.jpg   Newbie needs help, 275/35R18?-newwheels.jpg
Old Apr 7, 2014 | 01:23 AM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
Re: Newbie needs help, 275/35R18?
Yes, they work without modification. Only problem I've had with mine are rubbing the inner wheel wells at full lock with my vette wheels. IIRC you can fit a 315 in the back before tubbing.
Here's a couple pics for you.
Lowered (3" i believe)
Stock ride height
Old Apr 7, 2014 | 05:36 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Yes that tire will fit front and rear. But that wheel u posted is not available in a 9" width afaik, only 8" wide amd th at wheel wont work with a 275 tire.
Old Apr 7, 2014 | 01:50 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Wrong. They WILL work. Would I recommend it? Nah.
I have 18x9.5s rear and 18x8.5s front and 275s all around.
I'd think a 255/40/18 is what you would want, or if you're dead set on 275s for some reason, you could always have those wheels stretched.
Old Apr 7, 2014 | 03:50 PM
jhev1's Avatar
Car: 1987 IROC Z28
Axle/Gears: Stock
Thanks for the help guys. Unfortunately the wheels I really really (did I say really??) want have a backspace of 4.5, which will probably cause issues.
Old Apr 7, 2014 | 07:43 PM
Harvey Mushman's Avatar
Car: 83 Z 28
Engine: LG4
Axle/Gears: dunno
Stock ride height
Skinny
May I ask what wheel/tire combo you have on the red TA? That's the exact look I want
HM
Old Apr 7, 2014 | 10:15 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Originally Posted by Harvey Mushman
Skinny
HM
They are chrome 18x9.5 C6 corvette wheels. 275/35/18s all the way around.
I can't say I recommend that wide of a tire up front as they rub a little on the inner wheel well up front. If you can find some 18x8.5s as I did on the blue/silver one, go with a smaller tire as well and you shouldn't have a problem.
rubblerubble
Mar 13, 2016 06:57 PM
R3500
Aug 24, 2015 09:05 AM
jeepman
Aug 17, 2001 08:13 AM
83Z28
Carburetors
Jan 5, 2001 05:15 PM
