Dust Cap Interference
Old Jun 18, 2014 | 01:56 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
I'm installing my new wheels and the dust cap sticks out just far enough to prevent my center caps from going on all the way. Can I hit the dust caps in with a hammer (just a little bit) or do I need to increase my spacer size?
Old Jun 18, 2014 | 03:22 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Dust Cap Interference
You can do either or which ever you prefer
Try tapping it a bit fairly common issue with front hub
Old Jun 18, 2014 | 03:25 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
Awesome, thanks! I will take care of that later today. Now I only have to figure out a mysterious noise from the front end....
Old Jun 18, 2014 | 03:26 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If you're going to dent it in some, ENSURE that there is no metal to metal contact. You do not want to produce metal shavings that will get into and kill your bearings. Be especially careful that the cotter pin cannot slide around and come into contact with anything. Otherwise, no worries.
Old Jun 18, 2014 | 03:33 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Lol reading your post I can see some one getting biggest hammer and going to town lol
Yea just need to tap it if not comfortable remove dust cap and do it that way
It bends fairly easy
Old Jun 18, 2014 | 03:51 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
I was just about to ask, would it be better to remove the cap and do it then, to avoid metal shavings as naf said? If so, does the cap just pry off with a screwdriver?
Old Jun 18, 2014 | 04:37 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
I never had issues you have to really bang on the dust cap pretty hard to cause that
If you dont feel comfortable just remove it
Old Jun 18, 2014 | 06:08 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Jun 18, 2014 | 09:45 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Originally Posted by gt4373
The Dust Cap Rim Should Seat On The Hub.
Old Jun 27, 2014 | 10:04 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
Sorry I'm so late posting this, but shortly after I started this thread I got them to fit. I took an old Craftsman screwdriver and put the handle on the dust cap, gave it a few taps in a circle, and the caps popped right on. Thanks for the advice all!
Old Jul 23, 2014 | 09:15 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
An easy way is to put a washer inside the dust cover about the size of a nickel.
Install the cover, then tap it in until it stops. Then remove the washer & reassemble. The thickness of the washer will provide clearance so the dust cover will not contact the spindle.
sheachopper
Jul 31, 2019 11:27 AM
school boy
Oct 22, 2015 11:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Damon
Sep 26, 2015 04:29 PM
