10.5" OEwheels y2k on 4th gen rear
Old Jul 4, 2014 | 03:02 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
just wonder who has used what in terms of spacer. so far it looks like im going to end up with a ~.5-.6" spacer. (already have longer studs). would just like to see what others are doing there.
Old Jul 4, 2014 | 12:10 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
Re: 10.5" OEwheels y2k on 4th gen rear
If the Et is about 58mm or so you dont need any spacers in the rear with a 4:th gen axle
Old Jul 4, 2014 | 11:07 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
56mm
and it being up against the wheel well says otherwise. unless my car is lying to me..
Old Aug 19, 2014 | 08:28 AM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
That sure is strange. I have got the C5 magnesium Wheels on my car and the ET in the rear for those I Think is 65 and they only did hit the bumpstop, which I trimmed a bit of with a grinder. Still running 275/40 on those too and no issues..Now I´ve bought 2, 8mm spacers to put in the rear just to get them out more, mostly for the looks of it :-)
Old Oct 3, 2014 | 01:56 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
I think some of the Y2Ks are 9.5 and others are 10.5. I have mine (10.5) on a 4th gen rear and they're very close to the forward edge of the wheel well (near the pinch weld, that could be trimmed). I don't think I would need more than 1/4" right now, but I only have 275 wheels mounted. 305s may need a bit more space or some trimming.
Old Oct 23, 2014 | 09:09 PM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
I just put 285/35/18 in a 18x9.5 c5 speedline and i had to beat the front part of the rear fender inside, and then i got 1/4 spacers to be extra safe. no bump stop rubbing that i can confirm of yet.
Old Oct 23, 2014 | 09:11 PM
Car: RS Camaro
I also have a 4th gen rear.
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
