Balance issues, alt ways that last
Old Jul 31, 2014 | 02:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
lot of nasty rough roads, tire of losing wheel weights and paying to get it done.
[ I carry in my tires, so warranty isn't valid ]
contacted one of the balance bead companies and they said my 225/60/15 have to low of a profile.
post online about using a few oz of airsoft BBs
tossed a weight and nasty drive train vib at 50-55 up into stick.
Old Jul 31, 2014 | 02:52 PM
Joe Tag's Avatar
Re: Balance issues, alt ways that last
There are adhesive weights they mount inside of the rim (double sided tape). Unlike the traditional weights that hold grime behind them and oxidize the aluminum on the lip. Centrifugal force will only push them tighter to the wheel instead of slinging them off.
Old Jul 31, 2014 | 03:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Are they common at tire places or do ya buy them and take them in for em to use.?
Old Jul 31, 2014 | 04:01 PM
Joe Tag's Avatar
IDK haven't used them myself. Wife's '14 charger has them on it. I'm sure they're pretty common. These are what I'm talking about.
Old Jul 31, 2014 | 04:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
probably an aluminum thing like you mentioned, I have steel rims. maybe ya gotta ask as they default to clamp on with steel. Though last time they mention they did it so I had no weights on the outside, yet I can care less where they are, long as its balanced good.
never looked at a car and said oh geese, look at the ugly wheel weights........
tossed the weight July3 heading for fireworks, been ***** footin around stickin to the country roads where I can go 45-50 n just putt where im going......
Old Jul 31, 2014 | 04:16 PM
Joe Tag's Avatar
LOL I have, but never seen them until after my last balance. Had the weights put on the inside lip. After hours of sanding out the pits in my IROCs, rest assured I will have them next time.
Old Aug 4, 2014 | 10:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I gave in and just had Tireman balance the two in the rear, even thought only 1 way acting up.
was cheap too, only $15
Funny part was all the weights, ended up in different spots and sizes on both tires.
I could tell as I had put a coat of clear over the whole tire and rim. [ cheap tire shine that last months n months, hit the rubber with clear UV paint ]
Fronzizzle
Mar 18, 2019 08:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
theshackle
Aug 22, 2015 06:52 PM
crazynights
Aug 21, 2015 06:53 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
