Weld RTS question.
Car: 86' IROC-Z Camaro.
Engine: 4.8 H/C/I.
Transmission: TH 350.
Axle/Gears: Moser Axles, 4.10 gear.
Weld RTS question.
Is anyone running a 15x10 RTS on a 275/60? I'm gonna be ordering my wheels next month and I was wondering if you can run this combo. Either want a 15x10 or 15x9.
Car: 1983 Z28
Engine: 385 Fastburn
Re: Weld RTS question.
I have 275/60s on a 15x8. 15x10 should have problem running those.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
why dont you put a bigger tire on a 10in wide rim? 325/50/15? 275/50/15 isnt recommended for a 10in wide rim. what are you shooting for? performance or just a fat rim to have a fat rim?
Engine: 4.8 H/C/I.
I've seen 275/60s on 15x12s so thats not the problem. I'm talking about it actually fitting under the car with the right BS.
Engine: 4.8 H/C/I.
Going to be making some power when the turbo goes on, so I'm going to run a beadlock 15x10.
Engine: 4.8 H/C/I.
Hopefully going to be making 800whp next winter. I'll be getting the MT ET Street radial pro's.
Engine: 4.8 H/C/I.
X275 cars run 15x10 and 15x12 on a 275/60 and run down in the 4.30s. I'm probably going to go with a 9 though.
no green
Jan 9, 2016 09:22 PM
