Vibration and Centering rings
Old Aug 26, 2014 | 04:09 PM
S_Johnson's Avatar
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
I have some annoying vibration from my car, that seems to change whenever 1 or more of the wheels are removed and put back on.
I was told by a shop that since I have aftermarket rims, which don't exactly conform to the hubs, that I needed centering rings.
Is that a given? In other words, how much does that really effect vibration, etc?
I searched, but couldn't really find anything relevant.
Old Aug 27, 2014 | 03:54 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Vibration and Centering rings
Are the wheels the proper 5x4.75 (120.65mm) If They are 5x120mm rims I would look into Hubcentric rings for sure.
Jay
Old Aug 27, 2014 | 08:16 AM
S_Johnson's Avatar
Car: 87 T/A
They have two bolt patterns on them (not slotted/washer style though, they use standard acorn lugs)
Old Aug 27, 2014 | 03:29 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
hub rings are a must with aftermarket rims, some you can get away with but our cars are hubcentric not lug centric.
Old Aug 28, 2014 | 10:53 AM
S_Johnson's Avatar
Car: 87 T/A
That's interesting. I've been on thirdgen for like, 4 years, and rebuilt 2 firebirds, and I had no idea.
Thanks for the info!
Old Aug 28, 2014 | 03:36 PM
86iroct5's Avatar
wheels for our cars are supposed to sit snugly on the hub. aftermarket wheels have all different bores to fit different vehicles thats why they come with hub rings, think of it as a "spacer" to properly adapt that larger bore to the proper size for our car.
Old Sep 2, 2014 | 05:57 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Not true and you dont 'need, hubcentric rings or hubcentric wheels.
If you have dual pattern wheels they are most likely 5x120 not the proper 5 x 4.75 or 5x120.65. This is what causing the issue. In this case using hubcentric rings will aid you with this vibration issue, or you need to have the wheels redrilled with the proper bolt pattern.
If you look at the back side of the wheel it should say somehwere what the bolt pattern is. Bet you its 5x114.5 and 5x120
Old Sep 2, 2014 | 02:57 PM
86iroct5's Avatar
valid points. a rim could also be bent since he is moving it to the rear and not getting an issue but in the front hes getting a vibration.
Old Sep 2, 2014 | 08:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
That is also a possibility
Old Sep 3, 2014 | 04:03 AM
Jay_rich's Avatar
Car: 1987 Z28
Yup, if they are dual pattern I'm willing to put money on they are 5x120mm. Most companies only offer 5x120mm no a days. Pretty hard to find a 5x4.75 unless its a replica corvette/4th gen f-body, drag specific rim or a $$$$ forged wheel.
Whats the make of wheel?
Jay
Old Sep 14, 2014 | 12:21 AM
87350IROC's Avatar
Car: 87' IROC
86 is too humble.
If they are indeed 5x120, check out his method for fixing that. Very cool.
https://www.thirdgen.org/forums/whee...t-pattern.html
Old Sep 15, 2014 | 10:56 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Ive got adapters that are perfectly hub centric on the rear.... they are NOT hub centric on the fronts.
Thats when i realized for the fronts you are kind of at the mercy of whoever made your brake rotors as to hub diameter. Perhaps they were hub centric from the factory... but my rotors (now hubs) are nowhere near the same diameter as my rear hubs.
Food for thought.
Old Sep 15, 2014 | 11:44 AM
S_Johnson's Avatar
Car: 87 T/A
Ok, I took the wheel off, and looked for numbers. I found three.
They are "Pacer" rims, and I can't find a website, number ANYTHING. It's very frustrating.
2 of the numbers turn up nothing, 1 is apparently the part number for the "center cap" itself, which isn't helpful.
Not sure how to tell what they are at this point...
Old Sep 15, 2014 | 02:53 PM
86iroct5's Avatar
pacer makes very few designs for these cars, id assume they are the soft 8/D knock offs. which in turn likely have the proper bolt pattern but most certainly need the hub-centric rings since they are mainly designed for trucks.
pics would help
Old Sep 15, 2014 | 03:40 PM
S_Johnson's Avatar
Car: 87 T/A
Here's the best picture I have at the moment.
I really want to deal with this, because I REALLY need new tires, but I don't want to buy until I know the rims will work.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
