WIDEST WHEELS AND TIRES FRONT AND REAR WITHOUT SPACERS?
Old Sep 1, 2014 | 05:41 AM
nonricer's Avatar
Hi guys, i am wondering what the widest tires and wheels are that you can fit on a 3rd gen camaro with out wheel spacers, both front and rear?
YOUR HELP IS MUCH APPRECIATED
Old Sep 1, 2014 | 09:41 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: WIDEST WHEELS AND TIRES FRONT AND REAR WITHOUT SPACERS?
245s on 8" wheels is normal on the front. 275s on 9.5" wheels can be done, but you have to get the offset just right to avoid rubbing.
295s need at least 9.5" if not 10.5"... before you have to roll the lip and hammer the inner surface.
This has been covered to death, and a search will find plenty of information on wheel sizes and offset.
Old Sep 1, 2014 | 12:47 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
widest wheel with no spacer will be a 17x 9.5 by CTW Motorsports direct bolt on and can fit brembo brakes in them
i wouldn't run a 8" wide tire unless its stock rim IE 17" x 8 or 18" by 8 just seems your loosing handling performance unless your strictly want rims for looks
a 9.5 wheel all around will greatly improve handling on a thirdgen and good overall balance
can run a 10 or 10.5" with very little work at most rolling the lip but direct bolt on your going to have to go with a wheel from like ccw, fiske etc and thats more $$$
there are very very few direct bolt on wide wheels
also you can get 4th gen rear run corvette spec 10.5" wheels in rear and front get 2" adapter unless your running a big brake kit which you can run a 1.75" or 1.50" adapter
theres alot of threads but finding direct bolt on is going to cost you but CTW wheels are a very good price
Old Sep 1, 2014 | 04:29 PM
nonricer's Avatar
Having to modify the fenders doesn't worry me.
What if i have a 12 bolt in the rear?
http://www.hawksthirdgenparts.com/pr...-Assembly.html
Thanks for your help.
Old Sep 1, 2014 | 10:51 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
that's easy as long width stays true to 4th gen or 3rd gen specs so technically speaking nothing really changes , only thing that changes is strength swapping to a stronger axle
Old Sep 2, 2014 | 05:59 AM
nonricer's Avatar
So what is the most you can go with, when modifying the fenders?
Old Sep 2, 2014 | 01:44 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Read post above i posted
Old Sep 2, 2014 | 02:19 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
While you can go wider than 9.5" all around (would have to be 18" or larger), you run into the issue of spacers, costs, or in some cases, heavy modifications.
CTW Motorsports is my company, and yes we make a 20lb 17" x 9.5" wheel that will fit with no spacers and still clear 14" brake kits.
I have personally seen 10.5" wheels all around, 9.5"F/11"R and all sorts of other combinations, but you run into the spacer and/or cost constraint. A set of 3pc forged 18" x 10.5" wheels is going to run about $4k a set, where our wheels are a tad above $1k for a set in 17" x 9.5".
Old Sep 2, 2014 | 11:17 PM
nonricer's Avatar
Thank you for your help guys, it is much appreciated.
Old Sep 11, 2014 | 06:49 PM
lyrikz74's Avatar
What size and offset are your rims?
Old Sep 11, 2014 | 10:03 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
ones in sig xxr 521 18x10 +25 but since then they came out with a +12 which be a perfect fit and no need for adapter in rear and use small slip on front IIRC if you have BBK then wouldnt need anything in front
but with the +25 offset i used 1.25" F and 1" R adapter you can use no adapter on rear or small slip on but its up to you on the tuckage u want
tire size was 285 all around with room for 295
Old Sep 12, 2014 | 09:26 AM
lyrikz74's Avatar
If i go with the +12 is the lip going to be thick? Like that fat lip look yours has.
I might want to run a bit wider tire in the rear.. Thanks for the info man. Im building this car for my kid, and when i saw your car, i showed him and he flipped....
If you dont mind me asking, what did you use to lower it? what system?
Old Sep 12, 2014 | 02:03 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
using sportlines with rear insulator removed to reduce the rake it created to make for a more even stance, im now running intrax but will be investing in ground control setup after i get back from afgn. been lagging on my build big time but i work for uncle sam so he usally wins majority of my free time lol
both 12 and +25 are same lip size im considering going back to that setup myself since the +12 offset came out been alittle lost on what wheels to settle with
yea no worry shoot me a PM or post on my thread more than welcome to help you
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
