zr1 rims
Old Sep 17, 2014 | 09:01 PM
rdsxfn524's Avatar
zr1 rims
Will 19x10 zr1 replica rims work on my car? [/IMG]
Old Sep 17, 2014 | 09:07 PM
rdsxfn524's Avatar
Re: zr1 rims
If you can't open the pic they're 5x120.65 bolt pattern and
79 mm offset and 8.61 rear spacing
Old Sep 18, 2014 | 12:56 PM
rdsxfn524's Avatar
Re: zr1 rims
bump
Old Sep 19, 2014 | 04:31 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: zr1 rims
You will need around a 2.5" adapter for them to fit correct.
Jay
Old Sep 19, 2014 | 08:14 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: zr1 rims
you would need more like a 3-3.5in spacer with a 79mm offset
Old Sep 19, 2014 | 09:49 AM
rdsxfn524's Avatar
Re: zr1 rims
but heres the thing, theyre hub-centric so i need a hub-centric ring. can i use both?
Old Sep 19, 2014 | 09:55 AM
86iroct5's Avatar
Re: zr1 rims
you would technically need an adapter at the point not spacer im sorry i get the terms mixed up all the him.
but yes you would need a hub centric adapter, that is important
Old Sep 19, 2014 | 10:03 AM
rdsxfn524's Avatar
Re: zr1 rims
can you use the hub-centric adapter and a spacer?
Old Sep 19, 2014 | 10:15 AM
86iroct5's Avatar
Re: zr1 rims
I mean I guess so bit why not just get rhe proper adapter
Old Sep 19, 2014 | 12:12 PM
rdsxfn524's Avatar
Re: zr1 rims
with the proper adapter i will still need the hub-centric ring though
Old Sep 19, 2014 | 01:37 PM
86iroct5's Avatar
Re: zr1 rims
hub centric rings are only needed when the center bore is LARGER than the hub. this is a adapter to fill the void and eliminate possible vibrations.
Old Sep 20, 2014 | 10:14 PM
rdsxfn524's Avatar
Re: zr1 rims
you 100% sure? lol
Old Sep 21, 2014 | 09:23 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Re: zr1 rims
Sorry. Way too big for my peace of mind.
Old Sep 21, 2014 | 09:36 PM
rdsxfn524's Avatar
Re: zr1 rims
so what size adapter will i need?
Old Sep 22, 2014 | 08:13 AM
86iroct5's Avatar
Re: zr1 rims
Originally Posted by rdsxfn524
you 100% sure? lol
positive..
but as mentioned 3in adapter is huge... i would try to get a wheel that fits better
Old Sep 22, 2014 | 08:55 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: zr1 rims
Not sure how I feel about an adapter that big.... But once tightened down it should be no different than a wheel with a center hub that is that thick. it's not a spacer, it's an adapter.
Regarding adapters.... you want an adapter that is hubcentric on the car.... That will be tough on the fronts since the brake rotor hub may not be the same diameter as the hub on the rear. Mine are clearly not, and the base of the hub is radiused so I couldnt run a hub centric adapter on the front if I wanted to.
But notice my adapter is also hub centric to thew heel. There is no need for a hub centering ring here.
Old Sep 22, 2014 | 11:23 AM
rdsxfn524's Avatar
Re: zr1 rims
so it should be ok?
Old Oct 16, 2014 | 12:16 PM
rdsxfn524's Avatar
Re: zr1 rims
i saw somebody that had them said they used a 4th gen rear end so didnt need anything in the back, and up front used a 2.5 spacer i think
Old Oct 20, 2014 | 11:39 AM
Car: 1992 Camaro RS
Re: zr1 rims
Just depends on the offset. There are tons of different offsets out there. My 17x11's on a fourth gen rear would stick out 3/4 of an inch outside the fenders.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
