Tell me about this 16" crosslace wheel
Old May 8, 2016 | 09:40 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
What I know:
4.75" pattern
9" or 9.5"
positive offset; I'm pretty sure they are an aftermarket wheel for earlier C4 Vette fitment so they're not an ET0.
Does anyone know the maker or what they are called? Just wondering if others are out there.
Old May 9, 2016 | 07:04 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Tell me about this 16" crosslace wheel
Looks like a rear T/A or GTA wheel, except the center cap area, unless I'm missing something?
Old May 9, 2016 | 10:09 PM
jmd's Avatar
jmd
Well it's not 8" and I've seen the back before and it's not widened.
So I owe a backside picture.
Old May 9, 2016 | 11:11 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The tire on the rim in the picture is 245/50R16, and it doesn't look like a stretched fit, so the rim is, most likely, 8" wide.
Old May 11, 2016 | 06:15 AM
jmd's Avatar
jmd
It's about 10.75" total width, so it's 9.5" like I remembered.
I can't make out anything on the back regarding width or offset.
The front has JWL. The center is different from an 86-87 or 88-92 16x8 `Bird crosslace wheel.
Just wondered if it was a known aftermarket design.
Attached Thumbnails Tell me about this 16" crosslace wheel-cam02718.jpg   Tell me about this 16" crosslace wheel-cam02719.jpg   Tell me about this 16" crosslace wheel-cam02720.jpg
Old May 17, 2016 | 11:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Kinda looks like some late 80s grand am wheels
Old May 19, 2016 | 10:26 PM
jmd's Avatar
jmd
The 15" wheelcover version? I can see what you mean.
Old May 19, 2016 | 10:50 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
On laces
MAXWHEELLOAD1580LBS
JJS16 OFFSET ?K8?
Center
JAPAN
16SX
Old May 19, 2016 | 11:00 PM
BrutalGTA's Avatar
Car: 1989 GTA
Look what I found....
http://www.turbobuick.com/threads/he...estion.198887/
Old May 20, 2016 | 12:39 AM
LAFireboyd's Avatar
Here's a pic of the backside of a GNX wheel, saved from a Turbo Buick website forum. The GNX wheel is 8x16 with -15mm front/-23mm rear offsets, and it has the "dimples." The wheel in your pic does not have dimples.
Based upon the backside of the wheel in your pic, the MAXLOAD1580LBS is clean enough to read, and the JJX16 is almost clean enough to make out, but you'll need to wipe off the other parts of the inscriptions better because those are the rest of the sizes you're looking for: the number in front of JJX16(circled in yellow in the pic below, is the wheel's width), and the number after the word OFFSET(circled in red in the pic below, is the wheel's offset). Wet a rag and wipe them off.
It would be quite a stretch for a 245/50R16, which fits 7"-8.5" rims, to be mounted on a 9.5" rim, but whatever that number in front of JJX16 is, it's the width you're looking for.
Whatever the wheel is from, it's apparently not from a Buick Grand National/GNX, and it doesn't appear to be a GTA wheel either.
Old May 20, 2016 | 01:05 AM
jmd's Avatar
jmd
Yeah, it seems the center section paint keeps the numbers from being legible.
You'll just have to trust me on the size.
I measured them bead-to-bead about 10 years ago when they were bare. And externally last week.
There are a half dozen other 8" width wheels around here with the same size tire and the sidewall difference is noticeable.
They're 9.5" width.
Old May 20, 2016 | 01:10 AM
jmd's Avatar
jmd
Thanks Brutal.
Old May 20, 2016 | 08:18 AM
BrutalGTA's Avatar
Car: 1989 GTA
Thanks Brutal.
Always glad to contribute when I can.
I pulled this from that site as well. Might help in your search
"If it doesn't say front or rear than it's not a GTA wheel. Probably an ARE (American Racing) wheel. Where the lug nuts mount, is it inset or flat with the spokes? If flat with the spokes it's an ARE wheel. Riken made a similar wheel that I believe had wider webs, but I am not sure about the lug nut mounting surface. The ARE's also used a smaller center cap."
Possible brands (BBS or Riken or ARE or Enkei)
Old May 20, 2016 | 08:32 AM
BrutalGTA's Avatar
Car: 1989 GTA
Looks like they are probably Riken based off my "riken gta wheel" google search.
I attached 3 pictures of examples on a Fiero and a foxbody.
I love how the lil 5oh is trying so hard to be a T/A with the wheels and custom fender vents!
Old May 29, 2016 | 06:09 PM
jmd's Avatar
jmd
Brutal, you had it all figured out.
They are verified as Riken.
Old May 29, 2016 | 07:53 PM
BrutalGTA's Avatar
Car: 1989 GTA
Awesome! Glad to help.
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
cycleguy04
Wheels and Tires
Apr 9, 2014 12:52 AM
87_GTA_5.7
Jan 19, 2009 12:34 PM
82berlinetta350
Feb 11, 2003 05:52 PM
CrazyHawaiian
Aftermarket Product Review
Jun 21, 2001 12:37 AM
