Little Problem
Old May 9, 2016 | 02:42 PM
kleetis's Avatar
Car: 88 Camaro z28
Little Problem
So I don't know if this is where i should put this but it seemed like the best place. I recently put on Hubcentric Wheel spacers but at the time I didn't notice that when I put the Wheel on and tightened it down it was wedging Itself onto the hub. So know I cannot get the wheel of and it wont budge with anything. Please help.
Old May 17, 2016 | 05:09 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Re: Little Problem
BIG Hammer
Old May 23, 2016 | 11:39 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Little Problem
Call Thor.
Old May 23, 2016 | 04:06 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Little Problem
Normally when I have a stuck wheel, due to corrosion or what not, I have a 3lb rubber mallet that works pretty good after a few whacks.
Old May 23, 2016 | 05:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Little Problem
Bigger hammer, could try to heat the wheel, but that could damage the aluminum and ruin the wheel.
But a little confused, you can't get the wheel or or you can't get the adapter off?
M3638
Jul 14, 2016 09:16 PM
standard125r
Wheels and Tires
May 20, 2016 08:44 AM
billybob6110
May 11, 2016 06:20 PM
sahlomonic
Exterior Parts for Sale
May 11, 2016 09:49 AM
sahlomonic
Wheels and Tires
May 8, 2016 09:55 PM
