which tires & size
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
which tires & size
ok, i finally got my 86TA, WS6 running so now i have to get tires. the tires on it are 245/50/16" but i'm looking for a more low-profile tire. any suggestions on size and brand? i'm not going super expensive...
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: which tires & size
Are you keeping the 16" wheels or moving up to something larger?
Car: '85 Camaro
Engine: LG4
Transmission: 4L80E
Axle/Gears: 3.42:1
Then you should look into 245/45R16s for the front or all 4, maybe Toyo Proxes TQ 275/45R16 drag radials for the rear. There are no all-season choices in either size, so if you want to drive it all winter you'll need to stick to 50-series, like maybe the BFG g-Force comp-2 A/S 225/50R16. Shorter than your 245/50s, as much tread width as most Chinese 245s
The wheelwells already look under filled with 245/50s, any lower-profile 16s will only exascerbate the problem. The car will look silly to most.
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
thanks for the reply..... i'm kindof on a budget so i decided to get some 245/50/16 Doral SDL-A Performance Sport-touring tires for $315.00 shipped. i'll mount and balance them myself. getting the old tires off the rims is going to be a real treat though. i'll have to up a pic tomorrow so you can understand. these tires just fell apart. literally...
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
it might take me a while to get them mounted but only because i getting the old tires off is going to be a real bitch. ordering today. i'll let you know. oh, but in the reviews of this tire, there's a 3rd gen guy who praises them.
Car: '85 Camaro
Engine: LG4
Transmission: 4L80E
Axle/Gears: 3.42:1
I know a guy who got a Strongway manual tire change machine from Northern Tool for like $75, it paid for itself after 2 sets of tires.
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Get some Hawks 17x9 gta wheels and throw some 275/40/17's on all 4 corners. I did this to my 92 TA vert and it's such a massive upgrade!
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Car: 1989-TPI-GTA
Engine: 5.7
Axle/Gears: Limited Slip/Stock Gears
You can go up to a 255 like i have for maximum width, yet within wheel wells...front scrubs only slightly when turning tight to park.
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
I know a guy at the track that runs new all season continentals. He’s able to pull high 12s through a corvette swapped tune port motor in his 92 z28. His car is pretty stripped down and light as hell, but you can see it lifts the nose pretty well when he takes off.
