Rubbing issues
Old Dec 20, 2017 | 09:07 AM
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Rubbing issues
Hey guys and girls, hope you’re all well and Merry Christmas 🎄
I have these fitted to my car which has a stock 3rd gen rear end:
2x 18x8.5 23mm adaptor 255/45/18
2x 18x9.5 23mm adaptor 285/40/18
The car has been lowered 2” from stock and every suspension components is new. (Restoration)
The driver side rear wheel hits the arch when it hits a pot hole or while I corner and the road undulates beneath it and it’s sliced the tyre tread a good 5mm and of course it going to damage my arch.
Any suggestions other than decrease the tyre width?
Old Dec 20, 2017 | 09:29 AM
Abubaca's Avatar
Re: Rubbing issues
Run a 35 series tire instead of a 40.
285/40/18 is 27" tall
285/35/18 is 25.9" tall,
MUCH closer to (at least my) stock 245/50/16, which is 25.6" tall. Obviously width would help too, but width is COOL!!!!! -plust dropping an inch in diameter overall should give you a half inch (radius) of clearance, and it sounds like that should be enough.
Old Dec 20, 2017 | 09:30 AM
Abubaca's Avatar
Re: Rubbing issues
https://tiresize.com/calculator/
Old Dec 20, 2017 | 10:01 AM
Re: Rubbing issues
But the 40 is on the front, I’m not getting rubbing at the front!!!
Old Dec 20, 2017 | 10:17 AM
Abubaca's Avatar
Re: Rubbing issues
I'm confused. The 285/40/18's are in FRONT!?!?!!? ...with 255 out back?
Old Dec 20, 2017 | 11:18 AM
Re: Rubbing issues
Im sorry! I’ve had a beer this afternoon.
Of course you’re right. The 285’s are on the back. Ok so basically knock it down 5% on the side wall. I’ll have to wait until the next tyre change as these are very expensive tyres!
Would rolling the arches help in this situation because the 35 profile tyres I had these wheels first looked ridiculous!
Old Dec 20, 2017 | 12:27 PM
Abubaca's Avatar
Re: Rubbing issues
NICE!
I've never had to roll a fender/lip, and without really seeing the issue, it's hard to say if that'd help, but it certainly might.
As for the difference in size, I too prefer the look of a little more sidewall, but I plan on going with a 35 simply for fit when my new 18" wheels come in.
Old Dec 20, 2017 | 01:58 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Rubbing issues
Did you recenter the rear axle with a adjustable panhard bar? Could be why your rubbing on the driver side
Old Dec 20, 2017 | 01:59 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: Rubbing issues
https://www.ebay.com/itm/Umi-Perform...ZV0d3n&vxp=mtr
Old Dec 20, 2017 | 02:29 PM
Re: Rubbing issues
Yes it has an adjustable bar and i recentered the axle.
Old Dec 21, 2017 | 08:30 AM
Beater79TA's Avatar
Re: Rubbing issues
The other option that hasn't been mentioned is go to a 255/45/18 on all 4 corners. Unless you have modified the engine from the 2.8L listed on your profile, you really don't need 285's on the rear.
Old Dec 22, 2017 | 08:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rubbing issues
Not entirely true, just depends what you want the car to do. I ran 295/35/18 on all four corners of my 92 bird with a stock 3.1. Wanted the car to stick to the road and handle extremely well, and it did
For the OP
what shocks are you using? Larger and heavier wheels and tires need stronger shocks. If you still bottom out on the fender lip, the metal can be rolled, or consider raising the car some.
Old Dec 22, 2017 | 09:50 PM
Beater79TA's Avatar
Re: Rubbing issues
And tire compound is more critical than tire width. We won the autocross shootout at FBody Nationals this year on a 200 TW 255/40/17 Rival S tire on all 4 corners.
If the car is just a cruiser, moving down in size with proper tire selection won't impact handling and might even make it better.
Old Mar 4, 2018 | 01:26 PM
Re: Rubbing issues
Thanks for tall the advice guys. Turns out when I hit a MAHOOSIVE pothole, the shocker bent on the mount flange and the shaft and it's movement is a bit out of whack. Gonna swap it out, fix anything else thats bent and roll the arches. Will report back after that!
Old Mar 31, 2018 | 07:36 AM
Re: Rubbing issues
Well I swapped out the shocker and put the car through an alignment and is all good. Except it still rubs the arch lip going over dips and bumps.
Looking from the rear of the car it’s leaning 1/2” to the left (drivers) side. WTF? I’ve checked front spring isolators and indexing and it’s all fine, and done the same on the rear. Added the heater hose mod to the rear left spring and it’s made about 2mm difference which is obviously the thickness of the tube wall.
Any ideas? I’m thinking of adding a 1/2” isolator to the spring to level it up. I’m NOT buying weight jacks and any more new stuff, it’s getting real expensive!!
Old Apr 1, 2018 | 08:55 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Rubbing issues
If they rub the arch, you can roll the lip, use better shocks, or use different spacers to move the wheels in a little more.
As for the lean, for some reasons some cars do that some don't. Try the spacer, or maybe swap the springs to opposite sides.
Old Apr 1, 2018 | 10:43 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Rubbing issues
I bet you have a t-top car. If so then the chassis is flexed/twisted and theres no way to fix it. Best to put subframe connectors in and space up the low side and change to narrower rear spacers.
Old Apr 1, 2018 | 02:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Rubbing issues
Unlikely. Is quite common for these cars to be lower on one side in the rear, someone made a comment years ago that it was an issue with assembly and the quarters were set lower sometimes and gave the illusion the car was sitting crooked. My 86 for instance looks to be lower on the passenger side rear, but measurements from the suspension pickup points shows the car is level and square.
Old Apr 1, 2018 | 06:27 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Rubbing issues
Where was your car built?
I have owned over 11 of these cars and the t-top cars and verts tend to be tweaked. Some of the hardtops as well but not as much. I steer away from the hard top with the cracks in the upper rear corner of the door/roof connection. Clear sign of chassis stress.
actarnoff
Nov 23, 2013 12:54 AM
Berlyn0963
Wheels and Tires
Nov 27, 2012 05:49 PM
david068513
Sep 28, 2010 11:28 AM
Red92Bird
Apr 30, 2007 01:16 AM
Camaroguy18
Apr 17, 2006 01:03 PM
