Any experience with Mickey Thompson's Street Comp UHP tire?
Like the title says, curious if any of you guys have any experience with the MT Street Comp. Shopping for tires for those expected 17" Irocs from Hawk's. 275/40/17. Typically it seems MT tires are pretty good, and wow, that plane sidewall is just gorgeous! But it's gotta perform well too. Summit has 'em for $136ea. ...also looking at Continental Extreme Contact Sports at $176. -But there's no shortage of positive reviews of those tires!
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Any experience with Mickey Thompson's Street Comp UHP tire?
Just bought a set......... in that size. Used a coupon code a JEGS to get a pretty good deal on them. ( Priced @ $154 everywhere right now ) They just got delivered and still need to get mounted, but I'll I'll know how they roll soon enough & will re-post here sometime this spring with some feedback.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
I run them on my 17x9.....absolutely love them.
But I think Abubaca sold his car anyway....
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
I am running the 315 35 17 and I like them a lot. At the time I bought them off amazon they had the best price at the time with free shipping.
Don't let them freeze, but If they do freeze,... don't drive on them ! If you leave them on a car parked over the entire winter,...... there is a high probability that they will develop flat spots within a couple seasons. These tire compounds can NOT handle freezing temps !
TIRE TECH: DON'T DRIVE SUMMER PERFORMANCE TIRES IN COLD TEMPERATURES
https://www.tirerack.com/tires/tiret...jsp?techid=273
TIRE TECH: STORING PERFORMANCE SUMMER TIRES IN COLD TEMPERATURES
https://www.tirerack.com/tires/tiret...jsp?techid=220
Here's a quick review on the Mickey Thompson's Street Comp from AmericanMuscle.com:
I got 16 years out of a set of Nittos before the cracking rubber was too shockingly-severe to drive on the street any longer. I let the cracks get to an obscene depth before I was forced to relent and finally bought another set of 'sneakers'. Not going to be able to run the Vette wheels anymore, but it's been a while since my ride had ZR1's mounted on it and I'm looking forward to the wheel change.
My only experience with Mickey Thompson tires was a set of Indy Profile SS tires when the car was 'set-up' for straight line..........
I've bought plenty of Cooper tires and was glad when they bought MT and I'm glad to see the MT brand still on the market today. I don't know if these Street Comp tires will hold up over time,...... but they were priced right and 'checked all the boxes' on my search for new tires.
As with ANY "ultra performance" tire,...... you shouldn't leave them on a car during long periods of cold storage, allow them to freeze, and should never drive on them when temps are below freezing to avoid cracking.
Got them mounted on the GM ZR1's and will be ready for spring;
Not a bad deal,... mounted with new stems and the high-speed balance for under $700
They don't 'stick' as good as the Nittos,....... and I found that they make the car a bit "floaty" when overinflated.
I originally had the air pressure set in March but once the season changed and it warmed up outside I noticed the car handled a bit "funny". They were all a few pounds over max and they had to be deflated a bit. They stick good on corners at high(er then normal) speed and don't "squeal" much. Not a lot of road noise from them and they seem to be wearing even. (Well; the rear tires are a few thousand miles thinner than the front now -----> but that's my fault ! )
Overall; I'm happy with this set of rubber.
I did. But before I did, I ended up going with the Continental Extreme Contact, which proved to be a great tire. ...I have also since heard good things about the MT.
