How to remove paint from my Iroc Z center caps without damaging them?
Old Mar 9, 2019 | 07:47 PM
ragincaucasian's Avatar
Previous owner spray painted over the center caps and I want to reveal them is there any tricks to getting the paint off without damaging the caps?
Old Mar 9, 2019 | 10:58 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: How to remove paint from my Iroc Z center caps without damaging them?
It may be just easier to buy a new set.
Old Mar 10, 2019 | 02:32 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I've had luck with acetone (like you buy at a paint shop not finger nail polish remover) it will soften the paint and then you can get it loose with a pressure washer. Thought its likely to cause damage, its a last resort solution. It may be easier to get some plastic trim paint and just paint them, or buy some new ones since that is an option now.
Old Mar 10, 2019 | 02:45 PM
Thanks for the replies guys. I might try and get the paint off with brake cleaner if it doesn't work I'll buy a new set.
Old Mar 10, 2019 | 09:27 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I'd try a plastic scraper, the paint might not be sticking that well to the plastic. But anything that would remove paint would probably damage the plastic.
deoverton
Dec 3, 2008 09:19 AM
z28z34man
Sep 20, 2008 10:25 AM
The White Knight
Nov 4, 2007 05:37 PM
25THRSS
Jul 19, 2004 07:35 PM
