1990 GTA 16" rims. Best tire size for daily driving
Old Dec 25, 2019 | 05:24 PM
Nathan Rivers's Avatar
Hi, I've been fixing up this 90 gta. The side door says 245/50/16 forr front and back.
What would be the best size for casual driving. I'm not looking to take it to the track or anything like that.
I want to get the tires that would be the most comfortable for city driving.
Current there are 255 50 16 all around.
I dont mind if the front and back have different sizes tires if that would help with more stable comfortable driving
Any recommendations would be great.
And another question this car was sitting for years 10ish years. I got the engine running pretty good but is there so sort of addative I can put I. It to help refresh the gaskets?
Thanks and happy holidays.
Old Dec 26, 2019 | 01:38 AM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Re: 1990 GTA 16" rims. Best tire size for daily driving
No additive on the gaskets, if they're leaking replace them. if they're not your fine. Unfortunately your options for that tire size are limited these days, BFG still makes tires for that size.
Old Dec 26, 2019 | 02:43 PM
Ok cool, yea nothing is leaking just wasn't sure.
should I put the 255 50 16 all around?
Would signing different in the front help with steering?
Old Dec 26, 2019 | 03:08 PM
and i thought i saw the gasket refresher thing somehwere here. but couldnt find it again. i think called it "white" something but if its not necessary im not going to bother
Old Dec 27, 2019 | 09:45 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wheel Of Fortune
Best for DD'ing is the stock aspect ratio which will give you the best protection from potholes, etc.
You can still go wider and maintain the correct ratio.
Appearance is in the eye of the beholder.
To me low profile tires look like bicycle tires from the side.
The wheels associated with them look like wagon wheels in most cases.
Tires are a effectively part of the suspension.
Stock sidewalls absorb much of the road imperfections.
Stock size wheels are much lighter than oversized wheels, and a lighter car has many benefits.
The first time you drive over a bad pothole, that you probably won't see due to it being filled with rainwater, you'll be happy you maintained normal profile tires.
HappyRacing!
Help Combat Global Cooling - Accelerate As Fast As Possible
gta power
Wheels and Tires
Aug 22, 2013 03:32 AM
ExRacer
Sep 5, 2006 06:35 PM
ExRacer
Sep 5, 2006 02:33 AM
crazyL
Aug 2, 2005 09:06 PM
BigBiscuit
Aug 2, 2005 08:49 AM
