What is my bolt pattern?
Old Jan 1, 2020 | 07:58 PM
CherryBombZ2833's Avatar
I have a 1982 Camaro that I’m wanting to put wheels on. The wheels it currently has are Cragar wheels but the way these cragars are, I am not able to measure them to get my bolt pattern. From the measurement I have gotten, I believe it’s a 5x5 but that doesn’t make sense. I’m sure it’s still a factory rear. Wouldn’t they be a 5x4.75?
Old Jan 1, 2020 | 08:08 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: What is my bolt pattern?
As shown in your picture the PCD is 5x4.75
Old Jan 1, 2020 | 08:18 PM
So than my bolt pattern is 5x4.75? I thought you had to measure from the outside of one stud to the middle of the other?
Old Jan 1, 2020 | 09:10 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
https://www.performanceplustire.com/...-bolt-pattern/
Old Jan 1, 2020 | 09:41 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The graphics in that link are messed up, but the words describe the method the OP used.
Tirerack has a slightly different method that will make the number smaller, https://www.tirerack.com/tires/tiret....jsp?techid=92
And when in doubt, wikihow references a sweet little tool that takes out the guessing game, https://www.wikihow.com/Measure-a-Bolt-Pattern
Old Jan 1, 2020 | 09:59 PM
Drew's Avatar
Or you know, just go with 5 on 4.75 because it's a thirdgen and thirdgens are 5 on 4.75".
Might use a measuring tool that doesn't have a grip of play in the end too.
Old Jan 1, 2020 | 10:11 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I did a quick geometry workup. This will give you the bolt circle.
Best to measure starting at the 1" mark on your tape measure instead of the end.
1) Measure center distance between adjacent studs
2) Bolt circle = (your measurement) * 1.7013
Or you can use this website, https://littlemachineshop.com/mobile...circle_dia.php
Old Jan 2, 2020 | 10:45 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The graphic was OK my PC at home, but not this one. I think I pasted the wrong one.
I thought I was pasting in the adjacent x 1.701 link
Old Jan 2, 2020 | 10:03 PM
I tried the method with using 1.701 and it came up with 4.89. Still not giving me much sadly.
Old Jan 2, 2020 | 11:16 PM
I did a quick test where I put my front wheel on the rear and removed the top lug to see how much distance there was between the top of the stud hole and the stud itself. Than did the same with the front. Here’s what I got.
Old Jan 2, 2020 | 11:58 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I wouldn't make a cheap wheel with with oblong holes to be your gold standard.
The bolt pattern is 5 on 4.75" unless somebody has done something super stealthy to trick us all.
Old Jan 3, 2020 | 12:13 AM
The wheels that the previous owner put on are Cragar wheels and these ones are made to fit 4.5, 4.75 and 5.0 bolt patterns using a Conical Lug Nut with a washer. Not my opinion of a good wheel either hence why I’m trying to get new ones. And I’m not sure if he changed the rear end on it or not. I was told that it’s factory but he’s told me other things that I found weren’t the truth.
Old Jan 3, 2020 | 12:22 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It's probably just measurement error. It's never going to come out to 4.75 on the dot.
82-2002 Camaros have a unique rear axle, not shared with any other car, with a mounting pad cast into the center section where the torque arm mounts. 100% of them rolled off the factory floor with 5 on 4.75" bolt pattern. No other axle from another car could possibly be swapped in without custom fabrication and welding on a plate-steel torque arm mount.
I applaud you for being careful though. If you want to settle your mind then cross-check the part number on those brakes in the picture and make sure it belongs to an 82 Camaro.
Old Jan 3, 2020 | 08:44 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
That's only 150 thousand off 4.75, that's probably within margin of error for using a tape measure to try and make the measurement.
Like QwkTrip said, all 82-92 F-body rolled off the line with 4.75" PCD. If you still have a torque arm center section under there the ONLY way to get something other than 4.75" would be to swap out the axles. Might behhove you to just find someone else with a 4.75" wheel and see if it fits up on your rear. Would only take a few minutes of your time since you don't have a measurement tool.
Old Jan 3, 2020 | 10:02 AM
I’m trying that tonight. We’ll see how it goes.
Old Jan 4, 2020 | 08:12 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Since it had "universal" wheels with slots, I'm going to say the wheels studs are bent. Replace them all.
Old Jan 4, 2020 | 01:01 PM
Well, found out I have a 5x5 bolt pattern. Looks like I’ll need to continue looking for wheels as their are not a lot of options for 5x5.
Old Jan 4, 2020 | 02:37 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Alrighty, good luck with that.
Old Jan 4, 2020 | 09:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
What axle is in the car? Have you pulled the drum to see if the axles are drilled for 2 patterns? Not sure why somebody would go through the effort to convert to 5x5
Old Jan 5, 2020 | 01:07 AM
Axles are not drilled for two patterns and I’m not sure why the guy that built the car would’ve done 5x5 but than again, the guy also mounted the shocks upside down and didn’t know why it was hoping so much during burnout, launch and shifting lol
Old Jan 5, 2020 | 04:44 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
It's impossible to mount the shocks upside down
Old Jan 5, 2020 | 04:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
true.
I want to see the axle and suspension on the OP's car, but you something is fugged up to make that axle fit.
Old Jan 5, 2020 | 04:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
If you zoom in the pictures, I see what looks like a ladder bar contraption in place of the lca. That would explain a lot.
Old Jan 5, 2020 | 05:47 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Good catch, that would explain the issue
Old Jan 6, 2020 | 12:14 AM
Car is a drag car. Not street legal. Ladder bars and coil over suspension. Mounts on top and bottom of the shocks are exactly the same.
88FormulaKiller
Wheels and Tires
19
Apr 2, 2012 07:25 AM
IniTiaTe
Feb 25, 2007 06:27 PM
Whoodoo
Jan 31, 2007 11:17 PM
icarus402001
Nov 9, 2004 07:53 AM
TransAm87
Feb 22, 2002 11:12 AM
