Weld lug nut washer ruined
Old Sep 29, 2020 | 07:47 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
On almost every single lug nut, every washer is crushed. Any advice to this?
Old Sep 29, 2020 | 08:22 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Weld lug nut washer ruined
Looks like you're using shank lug nuts in taperd seat wheels?
Old Sep 29, 2020 | 09:11 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
yea, thats not the way to do it.
Old Sep 29, 2020 | 09:24 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
This is the wheel
Old Sep 29, 2020 | 09:28 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
It's hard to tell if those are taped seats or if the seats are just real messed up.
Can you tell us or take a better picture of the holes and seats?
Old Sep 29, 2020 | 09:34 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
To me, it just looks like the holes are wallered out a little. The seats definitely don't t look tapered to me. I think the previous owner over torqued the wheel and ruined the washer
It seems like a two piece wheel. It has some piece in between the two halfes that moves around when the wheel isn't bolted down.
Old Sep 29, 2020 | 09:57 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
yea, perhaps some serious over-torquing of the nuts caused the washers to distort, but still, shank style lug nuts should use flat washers, your setup just seems to have too much slop between all of the required components (wheel face, washer, nut, wheel stud)
Old Sep 29, 2020 | 10:50 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
What about possibly using gorilla washers, or possibly using some oversized grade 8 thick washers? You guys think that would work?
I'll take the wheel off tomorrow and see if I am using too small of a shank lug nut for it. If it is fairly tight in there, I may just get a pack of stainless steel oversized washers and throw on there
Old Sep 30, 2020 | 04:40 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Are the lug nuts the right length?
Old Sep 30, 2020 | 08:22 AM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Yes 1.375 inchs in shank length
gt4373
Sep 2, 2018 11:06 PM
gt4373
Jun 19, 2018 11:04 PM
z28cop
Jan 27, 2018 11:18 PM
gt4373
Sep 3, 2017 11:04 PM
Sonar_un
South Central Region
Apr 30, 2006 12:13 PM
